maf question
Old Jan 9, 2008 | 06:55 AM
choithew's Avatar
choithew
Default maf question
My maf sensor on my sc300 went bad and was wondering if i got the v8 maf (including sensor) if it will bolt up. I know people put the v8 maf housing in their cars to flow more air but i couldnt find if the same sensor could be used. sorry if its a stupid question but if i have to use the sc300 maf sensor w/ the v8 maf body to make it work it'll cost me more money since i'd have to buy the sensor separate. thanks in advance!
Old Jan 9, 2008 | 06:59 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Use the proper forum, pls.
moved.
Old Jan 9, 2008 | 02:11 PM
choithew's Avatar
choithew
sorry, please are the sensors the same in the v8 as the I6? my car is not running right now and this is the only thing left i need, so i just need to know if the maf sensor is the same on both. thanks
Old Jan 9, 2008 | 02:42 PM
Gunnar's Avatar
Gunnar
Are you asking if the plug is the same or if the sensor itself is the same? The V8 one will plug in just fine as far as I know, but I would doubt that it's the same sensor if it can read a lot more airflow.
Old Jan 9, 2008 | 04:09 PM
Dx3's Avatar
Dx3
Call Autozone and see if the part numbers are the same
Jonny
Old Jan 9, 2008 | 07:01 PM
LexAnt's Avatar
LexAnt
part numbers on the sensor are the same... it's the housing that are different.
Old Jan 10, 2008 | 03:59 AM
CantSeeMe's Avatar
CantSeeMe
If you're still using the stock intake box and piping you will need to modify the piping a bit . The V8 housing is just enough larger, that it wont fit as a direct replacement.
BTW I apologize if you already know this. But in case you didnt, Ordinarily the use of the V8 MAF in an SC300 is done in conjunction with a fuel inj and controller upgrade. And primarily as part of an Na-T project .
Old Jan 10, 2008 | 08:16 AM
choithew's Avatar
choithew
k thanks guys...
yes i have a turbo kit installed and all ready, when i started the car after i finished it all the maf was bad, so that is why i'm getting a new one, just wanted to make sure it would work.
Old Jan 10, 2008 | 09:04 AM
CantSeeMe's Avatar
CantSeeMe
Originally Posted by choithew
k thanks guys...
In that case, the LS MAF should plug right in.
Good luck
Old Jan 11, 2008 | 10:15 AM
choithew's Avatar
choithew
ugh i'm sorry but i've been searching forever, does anyone know what year range the v8 mafs are from the ls400 and sc400? i have a 95 sc300
simplecar
RX - 1st Gen (1999-2003)
Jun 6, 2019 12:48 PM
Jay hall
RC - 1st Gen (2015-present)
May 23, 2016 07:46 AM
PFB
May 15, 2014 08:42 PM
lexus-is2
Mar 26, 2013 07:12 PM
ronsmoove
Nov 25, 2012 04:16 PM
