Headlight Anomaly
Old Oct 23, 2025 | 05:56 PM
AlmostJake's Avatar
AlmostJake
Default Headlight Anomaly
Bought my wife a 2025 RX 350h P+ and am mostly happy with it. One gripe I have is the regular headlights. They both cast a weird shadow; and Im wondering if this is normal. I'm referring to the L shaped shadow at the top of the beam.
Old Oct 23, 2025 | 06:29 PM
Freds430's Avatar
Freds430
Purpose of the L-shaped shadow
  • Prevents blinding oncoming traffic: Lexus vehicles, like other manufacturers, follow regulations that require headlights to have an asymmetrical beam pattern. The driver's side headlight is intentionally aimed slightly lower and has a darker area to prevent glare from blinding other motorists.
  • Meets photometric standards: The design ensures the vehicle meets the strict lighting standards set by regulatory bodies, such as the Department of Transportation (DOT) in the United States.
Old Oct 23, 2025 | 07:10 PM
Urlik's Avatar
Urlik
Is that you Chat GPT? If so, go home...you're drunk.
Old Oct 23, 2025 | 09:11 PM
PortStLucieRX350's Avatar
PortStLucieRX350
Really can't tell much from your picture, but my RX also has a different pattern on the driver's side that doesn't go down the street as far and has a small shadow. I think what you're seeing is the normal light pattern designed not to blind oncoming traffic. Here is a picture from a Toyota forum. You can see it better here. Different vehicle, same idea:
Old Oct 24, 2025 | 02:35 AM
BMGS's Avatar
BMGS
Ignore the above posts referring to a standard DOT cutoff, your issue appears to be some kind of debris attached to the cutoff shield or on top of the lens. Can you take a photo of the lens itself or do you see anything in there similar to that shape? A photo might be difficult but you might be able to see something if you get in there close with an inspection light. It may be very small because its projected into a larger size onto the pavement.
Can you take a photo of the projection, one with the left headlamp covered with a towel and the other with the right head lamp covered with a towel? That would help determine which housing the issue stems from.
Old Oct 24, 2025 | 03:19 AM
Turbo4's Avatar
Turbo4
10th Gear
I don’t know what the weird shape is but it’s normal for standard headlights. My 24 Premium + has the same thing.
Old Oct 24, 2025 | 04:04 AM
PortStLucieRX350
OP, just so we're all on the same page, is this what you're talking about?
Old Oct 24, 2025 | 11:26 AM
AlmostJake's Avatar
AlmostJake
Yes, that's it. Both headlights have it pointing in the same direction.
I'll take a picture of the lens when the wife comes home (it's her car).
Old Oct 24, 2025 | 12:02 PM
PortStLucieRX350
I have to admit, I'm officially perplexed. I have never noticed that on my RX and have no clue what it is. Big help I am! LOL
I'll be following to see what the outcome is.
Old Oct 25, 2025 | 04:36 AM
Klamalama's Avatar
Klamalama
This is a resurrected old issue. My '23 has it. It's annoying only if you stare at it. Its purpose has been debated. I've seen no official response from Lexus.
Old Oct 25, 2025 | 05:20 AM
Eagleboy99's Avatar
Eagleboy99
We have the same sort of things in our 23 RXh 350. Kinda strange, esp. when compared to European lamps.
Old Oct 25, 2025 | 10:33 AM
AlmostJake's Avatar
AlmostJake
I took a good look at the headlights. Couldn't see any anomalies in the lens. I decided, when it's out of warranty I'm changing them out for some LEDs.
Old Oct 25, 2025 | 06:04 PM
Urlik's Avatar
Urlik
They already are LEDs.
Shervin350
Jul 15, 2025 08:07 AM
dbsoccer
RX - 4th Gen (2016-2022)
Dec 14, 2023 03:12 AM
Briankim79
Hybrid Technology
Apr 10, 2008 06:32 PM
ILOVEGIRLS
Lighting
42
May 26, 2006 12:58 PM
flm
Mar 13, 2002 09:33 PM
