ABS - Please HELP?
Old Oct 13, 2016 | 05:35 AM
tmosh's Avatar
tmosh
Thumbs up ABS - Please HELP?
Gents - Need your help here. I have a 2002 RX300 that has been an amazing car. It has 215k and is still going strong. Lately - the ABS is engaging at every stop - you can feel the pumping of the ABS system as you come to a stop. Took it to my mechanic - he replaced all the brakes - but could not fix the ABS issue. He said the brakes are fine - I just need to live with the ABS engagement. But - I simply can't live with the ABS engagement - it feels like 'rubber bands' when you put your foot on the brake pedal at a stop.
Using the forum information here (thank you) - I identified the 60 AMP ABS fuse in the main fuse box under the hood. That said - I cannot remove the fuse - it is simply too difficult to get out - and I am afraid I am going to break the fuse or damage the box.
Does anyone know how to easily remove the fuse?
Also - if I can't easily remove the fuse - is there another way to disable the ABS SYSTEM that is user friendly - without having to take the car to my mechanic?
Many Thanks
Old Oct 13, 2016 | 06:06 AM
maxSteel's Avatar
maxSteel
You can easily remove the ABS relay. It is mentioned in this thread
https://www.clublexus.com/forums/rx-...000-rx300.html
exact location:
https://www.clublexus.com/forums/rx-...ml#post6727931
Old Oct 13, 2016 | 07:00 AM
salimshah's Avatar
salimshah
25 Year Member
Welcome to Club Lexus tmosh.
Disabling is one but have you made an attempt to fix it. It can be expensive.
What you are dealing with is Sensors, controller, ABS modulator and one thing that is overlooked is the battery voltage and the alternator. Alternator and the battery voltage can be checked at any auto shop for free.
Salim
Old Oct 13, 2016 | 07:19 AM
tmosh's Avatar
tmosh
Thanks for your reply. I honestly have no interest in fixing it ( the ABS sensors, controllers, etc.). My RX300 has 215k on it - and I'm simply trying to hold on as long as I can without investing in it. Based on the forums here - it looks as though most people who have this issue are just happier running without the ABS feature.
Old Oct 13, 2016 | 07:20 AM
tmosh's Avatar
tmosh
Thanks for the reply Max. I will try to just remove the relay as you suggested. Many Thanks.
Old Oct 13, 2016 | 07:35 AM
maxSteel's Avatar
maxSteel
You're welcome. Mine's been disabled for a few years.
Pretty crazy advice from your mechanic about just living with flaky ABS engagement.
The brakes aren't 'fine' like that.
Old Oct 13, 2016 | 08:03 AM
tmosh's Avatar
tmosh
Wow .... Max -
I did it. Removed the green ABS module from your diagram just like you coached me to ... just test drove the RX300. Problem solved. You are The Man!
Wish I could buy you a beer! Way to go!! Thank you!!!
Old Oct 13, 2016 | 08:19 AM
maxSteel's Avatar
maxSteel
Glad to help and welcome to Club Lexus.
Old Oct 13, 2016 | 11:51 AM
salimshah's Avatar
salimshah
25 Year Member
Max there is a liability issue if a person removes/disables a safety feature. As an owner, you can choose to do that. I know we have been driving vehicles long before ABS and a non functioning ABS is always in the way.
I agree the brake job only would not fix the problem ,,, that is if the current brakes are able to stop.
Salim
Lexs400
Maintenance
May 24, 2023 05:51 AM
Androu
Aug 21, 2018 09:23 PM
deepbluesk
May 16, 2008 01:18 PM
MongolKhan
Jul 21, 2005 11:37 AM
