How do i get rid of ABS!!
Subscribe
Jul 17, 2005 | 07:38 PM
Hey guys, i have 1992 SC300 and would like to turn off or just get rid of ABS, if anybody has done this please let me know or can give me an advise.
Thank you very much.
I searched but nothing showing up, maybe i am searching wrong.
Reply 0
Jul 17, 2005 | 07:50 PM
I'd go check in the fuse box, there has to be a fuse for the ABS somewhere either under the kick panel or the hood. So take a look at the fuse boxes and see what u can find. Once u locate the fuse just pull it out and u should be set to go. ABS should no longer work.
Tommy
Reply 0
Jul 17, 2005 | 08:15 PM
What are the benefits of removing abs if any? I'm not being a wise ***, I really don't know lol.
Reply 0
Jul 17, 2005 | 10:10 PM
Quote: What are the benefits of removing abs if any? I'm not being a wise ***, I really don't know lol.
drifting! hahaha
Reply 0
Jul 18, 2005 | 08:24 AM
Quote: drifting! hahaha
Bingo.
ABS=Antilock Braking System. Prevents your brakes to lock when you slam on your brake pedal, personally, i think its the dumbest thing you can add to a car and this is what happens when you have abs in a drift car.
Reply 0
Jul 18, 2005 | 08:56 AM
I think it is one of the fuses located in the fuse box at the driver's side left knee. I was fiddling around with it replacing some fuses and when I took one of them out, my ABS light came on...probably means it was disengaged.
good luck
Reply 0
Jul 18, 2005 | 12:54 PM
Actually i found a ABS fuse under hood box too, will it just disengage ABS if i pull both fuses out or do i have to do something else as well, ill keep you guys updated.
Reply 0
Jul 18, 2005 | 11:42 PM
Rainy days are not going to be fun
Reply 0
Jul 20, 2005 | 09:18 AM
Quote: Rainy days are not going to be fun
That's why the fuse solution is great!!! Remove fuse at the track......enjoy sideways action......put fuse back in......drive home safely!! The best of both worlds!
Reply 0
Jul 20, 2005 | 09:26 AM
None, none whatsoever, you can still get sideways withouth disegaging abs.
Easiest way to do it put the better tires up front, and the worse tires on the rear, the sc will turn from understeer prone to oversteer happy rather quickly, as some members here have the unfortunate way of experiencing.
Reply 0
Jul 21, 2005 | 02:09 AM
Quote: None, none whatsoever, you can still get sideways withouth disegaging abs.
that may work for a slight "recreational" drifter, but this guy is on the track, doing it for real... he does not need NOR SHOULD HE WANT the ABS system to engage while entering a drift with aid of the braking system.
Reply 0
Jul 21, 2005 | 11:37 AM
so did removing the fuse work?
Reply 0
Subscribe
