Service E?
Old Sep 10, 2004 | 10:28 AM
super_cjc's Avatar
super_cjc
Question Service E?
My 99 RX has about 85K miles on it and the service writer recommends service E which includes timing belt, drive belts replacement. The cost for service E is $900.
Should I go to other dealers?
Old Sep 10, 2004 | 11:28 AM
HarrierAWD's Avatar
HarrierAWD
It sounds about right for 90K service at Lexus. You might be able to save a couple hundred dollars by going to a Toyota instead.
Old Sep 10, 2004 | 06:02 PM
LexRexBlue's Avatar
LexRexBlue
I didn't know it was called Service E, but I had my '99 RX done at 60, 000. The cost for it and oil change was $1350!!!
Old Sep 10, 2004 | 09:55 PM
kb2yza's Avatar
kb2yza
Not to sure of what all is in Service E either. However I would deff. recomend changing the timing belt. It is one belt that could total your engine if it fails. As far pricing goes I know its not a cheap service but if you want to get it done cheap Toyota dealers will best Lexus' price for sure. --Peter
Free iPod
Old Sep 13, 2004 | 09:58 AM
super_cjc's Avatar
super_cjc
Question
Thanks for all the info.
Any parts should be replaced while doing the 90k service to save some labor cost in the future? Things like water pump ...?
Old Sep 13, 2004 | 01:45 PM
mikey00's Avatar
mikey00
RX has a non-interference engine, so the timing belt will not total your engine as it will in interference engines.
Mike
Old Sep 13, 2004 | 07:06 PM
flipside909's Avatar
flipside909
Lexus Connoisseur
25 Year Member
Mike
Actually the 1MZ-FE & 3MZ-FE VVT-i models are interference engines. Non VVT-i models are the non interference models.
Old Sep 14, 2004 | 01:57 PM
Fern's Avatar
Fern
Default timing belt info
You had me concerned for a while (you must work for LEXUS), until I found this website which indicates our VVT-i engines are NON interference in fact.
http://www.aa1car.com/library/2003/us70343.htm
Or this site which lists the actual manufacturers and models that are interference/ non-interference engines
http://www.gates.com/downloads/downl...older=brochure
Cheers,
Fern
Old Sep 14, 2004 | 03:06 PM
mikey00's Avatar
mikey00
flipside909
Do you have anything indicating that the 1MZ-FE is an interference engine? Everything I can find agrees with the doc above from Fern indicating it is non-interference.
Mike
Old Apr 16, 2005 | 04:08 PM
parula's Avatar
parula
Default Interference rewind
Interference, or not, has reared up again, on this thread https://www.clublexus.com/forums/sho...d.php?t=159005 is there a definitive answer to this to put it the matter to rest?
Old Apr 16, 2005 | 04:50 PM
mikey00's Avatar
mikey00
It's begining to look like it may be an interference engine. I had 2 articles one a kind of vague article about Honda and Toyota engines and the other a PDF from Gates who manufactures timing belts. Both indicated non-interference. Gates has since modified the PDF on their website indicating interference.
Old Apr 17, 2005 | 10:45 AM
salimshah's Avatar
salimshah
25 Year Member
While we stirve to get correct information, keep in mind interfering or non-interfering there is the additonal concern of a breakdown at the wrong time (simple inconvinience to severe-accident).
Salim.
Old Oct 3, 2005 | 09:15 AM
Prime2u's Avatar
Prime2u
The last I read about this, was that the VVTi engines were interference, but they have valve reliefs built into the pistons that keep the damage from being quite as catastrophic if the belt fails. They should still be treated as interference engines though.
Lexgold400
Southeast
Jan 17, 2014 08:10 AM
lamar411
Dec 27, 2010 09:05 AM
ashley1977
Apr 6, 2009 01:24 AM
mrbdm99
Mar 17, 2009 10:52 AM
Legends6spd
Nov 20, 2002 10:43 AM
