Installed LexionKorea unit
Old Sep 17, 2021 | 07:27 AM
  #436
undergrou6's Avatar
undergrou6
Originally Posted by jmpickrell
That's odd. When you copied it to the drive did you get a notification that something (I can't remember what but I got a notification) was going to be removed from the file before it was copied? (Windows or Mac?)
No, nothing. I tried my Mac and 2 windows laptops.
Old Sep 17, 2021 | 07:39 AM
  #437
s3v3n's Avatar
s3v3n
At this point, hate to ask you but if you can shoot a quick video clip on the process of plugging the usb and going to android settings.
Old Sep 17, 2021 | 07:40 AM
  #438
jmpickrell's Avatar
jmpickrell
I'd second that. Nobody is saying you don't know what you're doing we just want to verify with those of us that got it to work the first time. Maybe there's some slight difference in what you're doing vs. what we did.
  #439
undergrou6's Avatar
undergrou6
Ok, I can do that later on, just dropped of the car to get some high-flow cats installed. I really do appreciate your help.
Old Sep 17, 2021 | 08:04 AM
  #440
dojoman's Avatar
dojoman
undergrou6's question and where did the "new" update come from? The supplier or you did some sort of over the air update?
I'm also not sure that's really a newer update because if you compare the numbers the original one is .1625 where this one is .1559. All the leading name is just the date is what compiled/saved on from the looks of it. I wonder if it actually is any different or if it's really the same version.......?
I received it from supplier they provided the mega link. There is no OTA update everything is through USB drive.
Old Sep 17, 2021 | 08:08 AM
  #441
undergrou6's Avatar
undergrou6
Wish it was OTA would be much easier to update.
Old Sep 17, 2021 | 09:22 AM
  #442
s3v3n's Avatar
s3v3n
Also, try some alternative media. If you have another USB stick, put some mp3s or video files in it and test if you can read them from the usb1 cable. Only to test if that cable is operational.
Old Sep 17, 2021 | 09:58 AM
  #443
undergrou6's Avatar
undergrou6
That’s not a bad idea. I will give that a try.
Old Sep 17, 2021 | 10:07 AM
  #444
dojoman's Avatar
dojoman
So after I did the update Android OS automatically generated a bunch of folders inside USB stick like Music, Videos, etc... if you see these folders which mean it was able to read the stick.
Old Sep 17, 2021 | 10:18 AM
  #445
s3v3n's Avatar
s3v3n
Same with mine. They system used the USB stick as temporary storage to extract the .img file.
Old Sep 19, 2021 | 11:56 AM
  #446
JT2MA71's Avatar
JT2MA71
Hi guys, although I am not having issues with my unit, I'd like to update the Android OS. I am having the same issue as undergrou6. I have tried 4 different USB sticks and tried both USB ports. I'm tempted to try using an SD card and try the SD card slot. Thoughts?
Old Sep 19, 2021 | 08:16 PM
  #447
jdmrcf's Avatar
jdmrcf
Anyone order their RC unit recently and how long did it take to arrive?
Old Sep 20, 2021 | 08:25 AM
  #448
rcJten's Avatar
rcJten
I tried the SD card route, no luck.
I am wondering if yo need to be on a certain OS version for this upgrade to work? For those that have successfully installed, did you note your current version before the upgrade?
Old Sep 20, 2021 | 08:26 AM
  #449
rcJten's Avatar
rcJten
My card is seen by the head unit. If I open file explorer I can see the USB stick mounted, and can see the .img upgrade file in the root directory, but the OS upgrade still says it cannot find.
Old Sep 20, 2021 | 09:24 AM
  #450
dojoman's Avatar
dojoman
delete....
