Installed LexionKorea unit
Old Sep 16, 2021 | 03:20 AM
  #406
harrychan's Avatar
harrychan
The device GPS antenna is for Google map .If use Apple carplay,this GPS antenna is not required
Old Sep 16, 2021 | 03:32 AM
  #407
harrychan's Avatar
harrychan
Looks very nice on the photos you shared
Old Sep 16, 2021 | 03:41 AM
  #408
harrychan's Avatar
harrychan
Originally Posted by vadimfrey
Hey guys, here is my review of Lexion unit on my 2015 RC350 (US version, made in Japan)
I really like the system, everything works as expected. Boot time is 20 sec, and backup camera works almost instantly (no need to wait 20 sec), probably 3-5 sec delay before the feed is shown
I use Android Auto on a wired connection (no wireless available yet).
Some highlights:
- Sounds quality is unchanged from OEM
- all OEM functionality is working: steering wheel controls, touchpad is responsive, park assist sensors work and shown on Lexion display, backup camera working (after harness swap), door open indicator is shown, volume indicator is shown
- No issues with calling using OEM microphone
- Can park and watch YouTube or Amazon Prime! (no Netflix available for some reason)
- installation is overall easy but takes time (about 4 hours) if you want to route all cables neatly. I followed youtube videos from BeatSonic on how to access behind radio and glovebox
- headunit's built-in microphone, GPS and WiFi all work
- screen quality is good, and it appears to be non-reflective
- no overheating issues (have been driving for 1 month), 2 longer trips over 1.5 hours
- factory menu is accessible and can be set to non-stretched view
- Apple Carplay works both wired and wirelessly
- Installed main unit behind glovebox, taped to SmartKey Unit on upper right
- Supports Airmouse (
Amazon Amazon
), in case I need to scroll through a lot screens or type (to keep screen clean and easier access). Sometimes I use it instead of touchpad to select things
- Fast shipping
- Solid support from Eric (LexionKorea)
Issues:
- AC Controls are not compatible yet for US models (fix is in the works), you can still control AC through factory buttons but you don't see inputs on Lexion screen. This unit does not support Fahrenheit units yet. This is very minor and doesn't bother me much
- Initial harness that I received didn't support backup camera, so I Eric sent me different harness compatible with my car version. Had to drive 2 weeks without backup camera (a bit annoying). After receiving new harness everything works
- Currently there is a bug with Android Auto and Google Assistant is not working (not Lexion issue)
I am appricated your comment
Old Sep 16, 2021 | 06:21 AM
  #409
jmpickrell's Avatar
jmpickrell
Originally Posted by s3v3n
For everyone who likes to update now, I just got the file.
https://mega.nz/file/DEEXwCoJ#REcmaN...tPDH2_zLM3OsmE
This is a 1GB+ file so this could be the whole OS update. I have not installed for I just got it and gotta go to work. The upgrade process may take a while since this is a big file.
Good luck and keep us posted if you get a chance to do the upgrade!
To update; just go to Settings -> OS Update.(instructions directly from him).
Sorry I don't know his name so keep on addressing as him (could be a her).
That link doesn't work. Do you have another spot I could download it from? (I don't know how I missed that he got you the updated OS?!?!)
Old Sep 16, 2021 | 06:37 AM
  #410
s3v3n's Avatar
s3v3n
The link was originally provided by the seller. But I re-uploaded the same file.
https://mega.nz/file/wZwG0YAD#Cl5IEm...HAHG-_HKnrpu28
Let me know how it goes.
Old Sep 16, 2021 | 06:40 AM
  #411
jmpickrell's Avatar
jmpickrell
Thanks. I'll get it downloaded here shortly and let you know how it goes. File size is 1.09gb, correct?
Old Sep 16, 2021 | 06:52 AM
  #412
s3v3n's Avatar
s3v3n
It reads 1.08gb on mine but that just depends on the partition type and operating system.
It reads 1.14GB when I copied it to a FAT32 format USB flash drive.
Old Sep 16, 2021 | 06:57 AM
  #413
jmpickrell's Avatar
jmpickrell
I got you. On the USB flash drive it reads as 1.14 for me as well. Thank you again!
Old Sep 16, 2021 | 07:05 AM
  #414
s3v3n's Avatar
s3v3n
My pleasure! Not everyone is getting luck on the upgrade installation so best of luck!!!
Old Sep 16, 2021 | 07:47 AM
  #415
jmpickrell's Avatar
jmpickrell
Went off perfectly. Appears to work fine at this point. If I run into any issues next time I drive the car I'll let you guys know!
Old Sep 16, 2021 | 08:17 AM
  #416
s3v3n's Avatar
s3v3n
Happy to hear the good results!
Key issues that was resolved for me.
1. Temperature sync
2. Backup Camera switching speed delay is now fixed - same speed as OEM when shifting to reverse.
3. Song playlists now plays without stopping randomly when Google maps is working.
4. Have never crash since the upgrade.
This OS upgrade seems very stable.
Old Sep 16, 2021 | 08:46 AM
  #417
jmpickrell's Avatar
jmpickrell
1. Temperature sync
Haven't tried with this new one but prior OS I also experienced the pointer icon not showing up for a while and music playing but no sound. (Fixed this by disconnecting BT and waiting a minute then reconnecting.)
Old Sep 16, 2021 | 09:14 AM
  #418
dojoman's Avatar
dojoman
Originally Posted by harrychan
I am the device producer.If need help,please email to sale01@binarytek.cn
Will you be active on this forum for future device support like OS update or we have to keep checking in through email?
Old Sep 16, 2021 | 09:19 AM
  #419
dojoman's Avatar
dojoman
1. Temperature sync
Prior to update I haven't noticed Home hard button working, now when I press it goes to Carplay Apps screen and Home screen. It's a nice touch, not sure RC has Home button. I do wish hard skip/play/pause buttons on Radio work, they don't do anything except play/pause button mute the sound.
Old Sep 16, 2021 | 09:28 AM
  #420
jmpickrell's Avatar
jmpickrell
My home button worked all the time between the hard press and soft press. I haven't checked the forward/backward buttons on the oem unit itself to see if they do the same thing yours' are doing.
