IS200t tune
Old Aug 20, 2019 | 07:26 AM
  #4036
OrangeVirus Tuning's Avatar
OrangeVirus Tuning
Originally Posted by chezgk
Hooray it wasn't the shrooms I was taking while driving can't wait to get this sorted out!
You can also send me a "draft" tune with the 3 modes extremely different from each other, just so you're sure you got them in the right order. My experience was Sport > Eco > Normal, not Sport > Normal > Eco. The draft tune would be perfect to really trace which is which.
It was definitely a confusing situation but I think we have it now.
I've got our dealer Rafael helping with this as well.
We are sending out updated tune files for all NX based ECUs right now.
Also we have a load control update that should smooth out shifting, (up and down) on all version cars. We expect to have that available asap
Old Aug 20, 2019 | 06:26 PM
  #4037
chezgk's Avatar
chezgk
That's great. I'm most likely within 15 Km of Rafael, so if you guys need dyno stuff, I can make my NX available by schedule.
Old Aug 23, 2019 | 04:46 AM
  #4038
OrangeVirus Tuning
If you don't mind, that would be excellent, we would love to get the car on the dyno
Old Aug 23, 2019 | 09:53 PM
  #4039
chezgk's Avatar
chezgk
I'll wait for the update to 78132 1.01G-C 002, then feel free to pass my e-mail address to Rafael. Thanks!
Old Aug 25, 2019 | 06:31 AM
  #4040
zhifan1's Avatar
zhifan1
anyone can comment on the turbo lag / throttle response issue after the tune? Thanks... thinking of improving the turbo lag, not looking or expecting better 0-60 times, but just wanna be able to overtake on the highway without the dreaded lag, which sometimes can prove dangerous.
Old Aug 25, 2019 | 07:43 AM
  #4041
WhyHateTho's Avatar
WhyHateTho
(OV Tune) Lag reduced, throttle response greatly approved, my wife noticed a difference and she's still trying to adapt. Not sure if it'll improve you trying to over take other drivers..
Old Aug 25, 2019 | 11:35 AM
  #4042
Thirst16's Avatar
Thirst16
So throttle response is greatly improved, however, minimal power improvements?
Based off of the dyno results, it showed around 100ft lbs of torque gained and +40 hp. Should be quite noticable to the driver and when it comes to over taking. Are you running lower boost?
Old Aug 25, 2019 | 01:24 PM
  #4043
WhyHateTho's Avatar
WhyHateTho
Results may vary and I've never Dyno'd. Besides tune and turbo muffler delete I have no other mods. Downpipe should help with power.
Old Aug 26, 2019 | 12:34 PM
  #4044
Miintt's Avatar
Miintt
Im running the standard flash with a downpipe and the throttle response is greatly improved even though its not the custom tune that gives the full 40 hp and 100 torque. The car does feel like it has more power on the first drive of the day but it does get heatsoaked extremely quickly so the power starts diminishing
Old Aug 26, 2019 | 01:02 PM
  #4045
Thirst16's Avatar
Thirst16
Yikes. Do you know what is causing the heat soak?
Old Aug 26, 2019 | 04:38 PM
  #4046
Miintt's Avatar
Miintt
I’m not too sure but I think its a bunch of things that contribute to it. Since the tune is increasing boost I think that adds to the heat in the engine bay. I’m running the injen intake which uses a metal pipe instead of the stock plastic so that can heat up quicker. I also had to remove the stock downpipe heat shield because of the aftermarket dp so that probably makes the problem worse too.
If anyone has any other ideas or can correct me please feel free to chime in - I’d like to know for sure too lol
Old Aug 26, 2019 | 06:06 PM
  #4047
DiverseIS's Avatar
DiverseIS
You could get a small turbo blanket. They work great! Also the PPE downpipe has mounts for the heat shield I believe.
I know another member hooked up the Toyota Prius coolant pump for the batteries to supply continuous recirculation to the heat exchanger. He put it on a switch to turn it on when running hard. I want to see how the coolant lines are ran for the heat exchanger to upgrade it.
Old Aug 29, 2019 | 04:42 PM
  #4048
OrangeVirus Tuning
We will be pushing out several updates to folks this weekend! Lots of things cleaned up and new transmission tune.
Also, we will be publishing our DIY Tuning solution for folks looking to tune their own vehicles tomorrow on our site Thanks. It allows for flashing, logging, and tuning the ECU yourself, along with a base tune from us
Old Aug 29, 2019 | 04:55 PM
  #4049
Miintt's Avatar
Miintt
Can everyone who has purchased the tune expect to receive the updated files automatically or will we have to specifically request it?
Old Aug 29, 2019 | 04:58 PM
  #4050
Miintt's Avatar
Miintt
I’m not sure if there’s enough room down there to fit a turbo blanket and it seems like it’s not in an easy place to get to. I’m running the TTI V1 downpipe so it doesn’t have the mounts for the heat shield unfortunately.
