IS200t tune
Old Aug 16, 2018 | 08:40 PM
  #3226
Flash5's Avatar
Flash5
Originally Posted by Sheddy
You will be fine with the data cable and Stage 1. All my BMS dyno results were done on the Stage 1. The JB4 gives users more tuning maps that work in conjuction with live readings, but no testing was done to show its potential.
Didn’t the JB4 help with the throttle issue though?
Old Aug 17, 2018 | 06:54 AM
  #3227
Sheddy's Avatar
Sheddy
From what i've seen the BMS Stage 1 reads "100%" throttle once the pedal is fully depressed with the "kick down" so it receives a WOT signal to start increasing the boost request. With the JB4, Terry made an adjustment that sends the "100%" signal when the pedal is depressed without going all the way to the kick down click, so it still doesn't address the throttle delay, but just alters the throttle signal. You would still want to hit the kick down since it drops to the lowest gear.
Old Aug 17, 2018 | 08:09 AM
  #3228
Flash5's Avatar
Flash5
Makes sense. Well unless there is some type of sale soon, I won’t be getting the JB4.
Old Aug 17, 2018 | 10:18 AM
  #3229
zhifan1's Avatar
zhifan1
Came acress this. They seem to be quite capable... anyone tried?
https://www.essingperformancecenter....45-hp-stage-2/
Old Aug 17, 2018 | 11:14 AM
  #3230
Sheddy's Avatar
Sheddy
Yea, your Stage 1 is capable enough. Just get the data cable and crank up the boost.
Looks like another piggyback unit. I highly doubt their HP claim is correct....
Old Aug 17, 2018 | 01:56 PM
  #3231
Ricoo's Avatar
Ricoo
what can you actually do with the jb4 system? I asked about the maps and apparently there aren't any yet
Old Aug 17, 2018 | 02:01 PM
  #3232
Flash5's Avatar
Flash5
It seems that as of right now all you get is monitoring capabilities which I can already do with my Bluetooth OBDII. The boost changes and stuff still happen on the actual tuner with the data cable to a computer.
Old Aug 18, 2018 | 09:15 AM
  #3233
mvaldez24's Avatar
mvaldez24
This is an email I got from someone over at BMS. No real difference YET. JB4 is still similar to the Stage 1.
Old Aug 18, 2018 | 03:24 PM
  #3234
Sheddy's Avatar
Sheddy
My JB4 had the Infiniti Q50/Q60 motherboard so it had similar settings. Once the Lexus JB4 is fully developed it will have different map with boost settings.
I do have a BMS Stage 1 with data cable that was used for less than a month if anyone is interested.
Old Aug 18, 2018 | 03:27 PM
  #3235
Flash5's Avatar
Flash5
Damn it I was going to try to buy the data cable off you but it’s the one for the tuner with no case lol
Old Aug 18, 2018 | 03:29 PM
  #3236
mvaldez24's Avatar
mvaldez24
How much you letting it go for Sheddy? Willing to ship 85033? This would pretty much be all I need, right?
Old Aug 18, 2018 | 03:46 PM
  #3237
Sheddy's Avatar
Sheddy
I'll let it go for $320 shipped. It comes ready to plug and play, I can connect the data cable for you as well.
@Flash the gray connector on the data cable can be removed to work with the case.
Old Aug 18, 2018 | 03:58 PM
  #3238
mvaldez24's Avatar
mvaldez24
I can do $320.
Honest question, is it worth it to just get the JB4 already or am I good with the Stage 1 for now? I can still adjust boost with the data cable with stage 1?
Planning on getting down pipe too.
I was going to get my intake but rather use the money I got to buy your stage 1.
Old Aug 18, 2018 | 04:17 PM
  #3239
Sheddy's Avatar
Sheddy
The JB4 will have more features than Stage 1, but they are both doing the same job. With the data cable you will be able to adjust the boost settings higher with the addition of the downpipe.
Old Aug 18, 2018 | 07:53 PM
  #3240
Ricoo's Avatar
Ricoo
This is what I got. Jb4
