LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
9005 bulbs
Old Dec 23, 2018 | 05:20 PM
samuraj's Avatar
samuraj
Default 9005 bulbs
good luck changing hi beam bulb on driver side ........with out removing battery .
BTW do you know , bulbs are mounted side ways in the housing ????
Old Dec 23, 2018 | 05:39 PM
samuraj's Avatar
samuraj
this is it # 10
Old Dec 24, 2018 | 01:15 AM
Chocolate's Avatar
Chocolate
It's a tight fit, but doable without removing the battery.
https://www.carcarekiosk.com/video/2...ights/highbeam
I have upgraded both the fogs and highs to LED replacements, but I never use the highs. The fogs actually put out much more light on the road.
Old Dec 24, 2018 | 05:00 AM
samuraj's Avatar
samuraj
Is someone making good quality LED bulbs ?
i hear only complaints.
Old Dec 26, 2018 | 06:13 AM
Reggie1's Avatar
Reggie1
I replaced my battery recently. Removing it is quite easy to do . Loosen and remove the negative and positive clamps, then a single hold down bolt. All three are easily accessible from above. Then lift the battery right out. So don't let the possibility of having to remove the battery stop you from changing a headlight bulb yourself.
Old Nov 3, 2020 | 06:56 AM
glemmen1's Avatar
glemmen1
I know this thread is about high beam, but I have a headlight out on the driver side.
I am looking for guidance, has anyone replaced?
anyone have suggestions on bulb brand and/or tips for DIY.....
Old Nov 3, 2020 | 11:48 PM
nayak1's Avatar
nayak1
I have replaced 9005 & 9006 LED bulbs over a year and half ago. They are way better than traditional halogen. Straight plug and play. See below the link.
Amazon Amazon
Old Nov 4, 2020 | 06:12 AM
z32's Avatar
z32
I replaced my factory HID bulbs w/out needed to remove the battery. A pain imo would be removing those plastic engine bay covers w/ like 18 clips or so.... Otherwise fairly straight forward.
Old Nov 4, 2020 | 06:41 AM
glemmen1's Avatar
glemmen1
what did you replace with? link?
Old May 2, 2022 | 12:36 PM
BaronJeff's Avatar
BaronJeff
I got some 9005 LEDs to replace the High Beams on my 2013. The LEDs have little fans on them. Did you re-install the dust covers or leave them off?
Old May 2, 2022 | 01:25 PM
hankinid's Avatar
hankinid
They're usually left on.
8055y
12
Apr 2, 2018 10:15 AM
thizhkboi
Oct 9, 2017 11:25 AM
rustytank
May 13, 2014 07:55 PM
Jewmack
Dec 18, 2012 12:17 PM
scottinky
Feb 6, 2011 06:55 PM
