2007 ls 460 auto headlight problem
Old Mar 7, 2018 | 11:07 AM
SY GOLD's Avatar
SY GOLD
Default 2007 ls 460 auto headlight problem
The headlights will not turn off after the car is shut off. I do not need a dead battery.
Old Mar 7, 2018 | 11:35 AM
PwrdbyM's Avatar
PwrdbyM
Without insulting your intelligence we might need some additional info.....
The car has a "coming home" feature that will allow the lights to stay on for up to 90 seconds. So with the key removed from the vehicle, the doors locked, and having waited at least 90 seconds you're saying the lights are still on?
Old Mar 8, 2018 | 08:30 AM
Dx3's Avatar
Dx3
The door sensor is going bad on one of your car doors (most likely drivers door). Switch the drivers side sensor with one on a door you don't typically use (passenger rear). Takes about 30 seconds to do. Then your headlights will shut off.
Old Mar 9, 2018 | 12:40 PM
R Z's Avatar
R Z
I have also noticed my lights sometimes never turn off. I'm careful to watch them go out before I leave the parking lot or my garage.
Old Mar 9, 2018 | 01:19 PM
riknchar's Avatar
riknchar
Sounds like you have a sticking driver's door switch, which is very common. The good news is the switch is very cheap and very easy to replace. Good luck!
Old Mar 9, 2018 | 01:55 PM
jmcraney's Avatar
jmcraney
The likely cause of your lights remaining on is a defective doorjamb switch. We've discussed this extensively in our forum.
The defective doorjamb switches are the prime causes of mysterious battery discharges. Testing the switches is very easy and replacement is inexpensive and a DIY project for many. Replacement parts are readily available through Lexus and Toyota dealers.
Here are some links to a few of the threads where the doorjamb switch problem has been discussed.
https://www.clublexus.com/forums/ls-...tery-fail.html
https://www.clublexus.com/forums/ls-...xperience.html
https://www.clublexus.com/forums/ls-...s-stay-on.html
https://www.clublexus.com/forums/ls-...w-battery.html
https://www.clublexus.com/forums/ls-...-switches.html
https://www.clublexus.com/forums/ls-...l-problem.html
https://www.clublexus.com/forums/ls-...lacements.html
https://www.clublexus.com/forums/ls-...mb-switch.html
https://www.clublexus.com/forums/ls-...-turn-off.html
If you don't want to wait to see if they will go off, you can truncate the delay by hitting the lock button on the wireless electronic key twice. Try it - you'll like it.
Old Mar 11, 2018 | 10:29 AM
joedaddy1's Avatar
joedaddy1
i am lazy.. what's the part number?
Old Mar 11, 2018 | 11:35 AM
roadfrog's Avatar
roadfrog
We're lazy too....find it yourself.
Old Mar 11, 2018 | 11:59 AM
Kansas's Avatar
Kansas
It might be 84231-50190
Google the part number and see if that looks like it.
Edit: More than one part number is shown:
84233 SWITCH ASSY, COURTESY LAMP (FOR FRONT DOOR)
84231-50190 (04/2007 - 08/2008)
84231-53010 (08/2006 - 02/2007)
bobrxlex
Feb 12, 2019 07:58 PM
garyr
Aug 7, 2015 08:55 PM
PDubs
GX - 1st Gen (2003-2009)
Dec 21, 2012 04:06 PM
firstimer
Dec 29, 2011 08:07 AM
carcass66
Aug 20, 2004 07:22 AM
