2013 LS460 Electrical Issues
Old May 31, 2025 | 11:04 PM
Abdulrahman7x's Avatar
Abdulrahman7x
10th Gear
Originally Posted by tammap
If you have an OBD scanner, perform a full systems scan.
Originally Posted by Anfanger
It is likely water intrusion. Did you check for error codes?
Did an OBD scan, and got these three codes:
U0073 Control Module Communication Bus off.
U0100 Lost Communication with ECM/PCM/EV.
B2427 CAN Lost Communication.
I think it has something to do with the wiring and connectors, but would really appreciate any advice.
​​​​​​​many thanks to you all.
Old Jun 3, 2025 | 01:45 PM
Anfanger's Avatar
Anfanger
One of common issues is a weak battery.
Old Jun 5, 2025 | 09:58 AM
Abdulrahman7x
10th Gear
I thought that might be the issue, but I did actually change the battery and the problem is still there unfortunately.
Old Jul 1, 2025 | 12:20 AM
Abdulrahman7x
10th Gear
I think I’ve found the solution, I changed the mirror switch assembly (as shown in the picture) and the problem disappeared, it’s been three days and the problem never came back!
but there is a slight difference maybe in my issue, when the issue occurred a “check headlight system” message pops in the dash, just a thing to keep in mind.
many thanks to all!
Old Aug 6, 2025 | 07:06 PM
dansonted's Avatar
dansonted
Hi all, can confirm that replacing the module indeed fixed it completely for me as well. Thank you @Abdulrahman7x !
Old Aug 7, 2025 | 01:50 PM
sktn77a's Avatar
sktn77a
Seems there are quite a few folks here with this problem. Surprised the dealers haven't come across it(?)
IgorM
Dec 10, 2021 08:15 AM
Faster88
Aug 28, 2021 04:31 AM
jimshaw
Nov 20, 2016 04:05 PM
416tt
Aug 16, 2016 09:52 AM
zkl2003
NX - 1st Gen (2015-2021)
14
Aug 3, 2016 07:16 AM
