Help please....no info screen
Old Sep 8, 2015 | 09:55 AM
honeygee2's Avatar
honeygee2
Default Help please....no info screen
03 ls 430 with mark levinson and Nav. Little info screen above. Nav screen flickers on and off constantly. The screen shows outside air temp , AC temp settings and clock. Can only use side buttons when screen flickers on. When it does come on it shows on the clock 1:00. Have banged on dash, replaced fuse etc and cannot get the screen to stay on. Any help would be appreciated. Thanks
Old Sep 8, 2015 | 11:29 AM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
i am guessing that your nav unit is shot and you will have to get it rebuilt or buy a rebuilt one to replace it.
Old Sep 8, 2015 | 11:31 AM
johnnylt's Avatar
johnnylt
just a thought , maybe disconnect negative battery cable/I have an 05 , I hope that don't happen , I ve heard very $$$$ to replace
Old Sep 8, 2015 | 01:36 PM
BradTank's Avatar
BradTank
I would probably start looking for one from a salvage yard and swap it out. It's just sort of a reality that something electronic like this this will eventually go out.
Once in a blue moon my screen will go blank but it always comes back on when I restart the car.
I would imagine something like this would be big bucks from a dealership brand new, so I would try my luck with a used one.
Old Sep 8, 2015 | 03:41 PM
johnnylt's Avatar
johnnylt
Brad what year is your lexus ? and model
Old Sep 8, 2015 | 04:08 PM
BradTank's Avatar
BradTank
2004 with the Mark Levinson/Navigation.
The screen going dark has only happened like 3 times since owning the car, but it's still concerning.
Old Sep 8, 2015 | 04:51 PM
Chemtj's Avatar
Chemtj
I had very similar problems with the screen on my 04. Connected with a guy on EBay that repairs navigation screens. Search for LS430 nav screen repair. He did a great job for me and very inexpensive, around $200 if I remember correctly. He was local to me so he even removed and reinstalled mine for me. It has worked perfectly since. Contact him through his listing and see if he can help.
I have no relationship with him other than he repaired my screen and I am not compensated in any way.
Hope this helps.
Old Sep 9, 2015 | 07:38 AM
Fixman's Avatar
Fixman
If it's the screen that is defected. A new screen is for about 150 $ or so. You can find it on eBay or the other China web site.
Old Sep 9, 2015 | 09:56 AM
BradTank's Avatar
BradTank
Hope this helps.
Do you know what the problem ended up being? Was it something like the power supply?
Good to know there is an affordable alternative, I would rather pay $200 to have it repaired by someone reputable than taking a crap shoot with a salvage yard unit.
Old Sep 9, 2015 | 06:14 PM
Chemtj's Avatar
Chemtj
I believe that there is a common problem with solder joints at the main bus at one of the circuit boards deteriorating. That is what I have deduced from much research prior to having mine repaired but I am no electronics wiz. That is why I wouldn't try to repair mine myself. I wouldn't even attempt to remove my unit myself though after watching the guy remove mine it is actually simple (if you know what you are doing). In any case, he tested the unit and repaired whatever was wrong with it. He told me that all of the local Lexus and Toyota dealers have him do their repairs then they charge huge markups. He had mine done in two days if I remember correctly. Your experience may be different than mine but I was very happy with the repair. I believe he would help you troubleshoot and tell you how to remove the unit if necessary to ship to him or if you are lucky and are local to him you can take your car to him. He was very busy and took a day or two to connect with but in my case was worth the delay. I made initial contact through his eBay listing and he sent me contact info. I may have even paid him through eBay but don't really remember. Good luck with any route you take to repair or replace your unit.
Old Sep 13, 2015 | 06:56 PM
honeygee2's Avatar
honeygee2
Thank you all for the replies. When the panel is lit up,I can access the Nav screen and it stays on while the top panel still flickers Any thoughts
Old Sep 10, 2016 | 06:05 PM
LSxtacy's Avatar
LSxtacy
Do you happen to have this guy's name or contact info?
Old Sep 12, 2016 | 08:49 PM
tallcaguy's Avatar
tallcaguy
Have the NAV unit in my 2004. One of the few things I don't like. Sounds like possible problems include 1) defective screen 2) soldered connections failing and 3) power supply. Hopefully the worst case is less than $500. Planning forward for when it fails (which is inevitable w/ a 12 yr old electronic device w/ screen display). Thanks for the info.
Old Apr 24, 2017 | 02:39 PM
Jbreezie's Avatar
Jbreezie
Play with the home and menu button and you will get the screen you like. I usually do the 4 way split or just navigation.
honeygee2
Sep 8, 2015 06:43 AM
DexRox512
Jun 30, 2015 03:14 PM
s6 4rings
Dec 14, 2012 05:16 PM
houstonnw
Apr 10, 2012 11:58 AM
04_LS_430R
May 24, 2008 11:31 AM
