What mirror part do I need? -- please help
Old May 17, 2014 | 11:32 AM
Bobjann's Avatar
Bobjann
Default What mirror part do I need? -- please help
The passenger mirror on my 2002 LS430 struck something after which caused some of the plastic parts to break off that connect the mirror to the rest of the guts of the mirror. The mirror hung from the housing attached by only few small wires. The outer mirror housing is undamaged. It still retracts when I power down. To fix this problem, does anyone know what part number(s) I need to order?
Old May 18, 2014 | 06:23 AM
bmore430's Avatar
bmore430
Check the sewell website for the exploded view of the mirror and part numbers. Order whatever pieces you see broken or buy a used complete mirror from salvage yard and pick what u need.
Old May 19, 2014 | 06:15 AM
Bobjann's Avatar
Bobjann
Thanks. I checked them and now I have this dilemma. Those diagrams do not show the inner mechanical and electrical parts of the mirror. It look like if the outer part of the mirror is OK but a plastic part from the inner workings and from the mirror itself both broke off, I need to spend almost $750. Can t his be right??
Old May 19, 2014 | 09:47 AM
bmore430's Avatar
bmore430
Yea 700.00 each is what the whole mirror runs and lexus doesn't even mess with taking them apart if something is broke they just put a whole new assembly on so that could be why it isn't showing in the parts views.
You checked ebay, craigslist and the net and no used one's are coming up at all? Maybe look for a salvaged ls430 that's wrecked for sale and message them if they'll part out anything. I've seen these pop up before.
Old May 26, 2014 | 10:06 AM
Bobjann's Avatar
Bobjann
Thanks, bmore430. That clears things up for me.
Old Jun 1, 2014 | 08:14 AM
goldmax60's Avatar
goldmax60
Thumbs up Exterior Mirror Assembly
If you register with the Sewell site and let them know that you belong to Club Lexus, you can get a good discount on parts. I am going to buy the right side mirror mechanism for about $350. This doesn't include the hyper expensive mirror but it will solve all the mechanical problems with the mechanism.
Old Jun 2, 2014 | 06:54 AM
Bobjann's Avatar
Bobjann
Thanks for your reply. I am registered with Sewell and have used them in the past. You are not kidding about the hyperexpensive mirror.
Old Jun 9, 2014 | 08:11 AM
goldmax60's Avatar
goldmax60
Default Lexus Mirror
Bobjann....I, too, have a 2002 LS-430. I am planning to replace my passenger side mirror this summer. The up-down function has ceased to work and it only folds in about 80% of the time. Go to the Sewell Lexus site and register as a member of Club Lexus. When you do that, you will get great discounts on parts. The mirror will cost $329.71 and they stock most of them. You will need to select your color by color code. Shipping will be extra...usually about $15 depending on where you live. This is for the mechanism so be careful not to break the glass. It is $247.34 by itself. I replaced mine last year with a used one I bought for $125. Good luck.
2002 LS-430 Parchment Chrystal - Code 66 - 130,000 smooth miles.
Old Jun 16, 2014 | 06:25 AM
Bobjann's Avatar
Bobjann
Thanks, Goldmax60. So, the the housing (the part for which you have to choose a color) contains the motors but it does not include the actual mirror itself. You have to buy the mirror as a separate purchase. Am I correct?
Old Jun 23, 2014 | 12:50 PM
goldmax60's Avatar
goldmax60
Default LS-430 Outside Mirror
Yes, that is correct.
Pearlpower
Sep 4, 2022 03:25 PM
francis123
Jul 12, 2014 04:04 PM
zackteee
Dec 1, 2013 09:42 PM
LEXuriouss
Jan 22, 2007 12:46 AM
