Coin Box doesnt open :(
Old Jul 13, 2011 | 09:48 PM
Bobzi's Avatar
Bobzi
Default Coin Box doesnt open :(
Heyz every oneee i hope you can help me here. the coin try under the mirror control buttons doesnt open. donno its jammed or wat!! i have the LS430 the 2001 model. Can any one help? if any one have photos on how to open it or sth i would appreciate it
Old Jul 13, 2011 | 10:18 PM
GLIDESUL's Avatar
GLIDESUL
Yours don't open mines won't stay shut wanna trade. Lol the tray is like 1 hundred and some change sucks.
Old Jul 14, 2011 | 06:47 AM
McSwine's Avatar
McSwine
Mine can be contrary as well. I've found I can get it open if I use my fingernail to kind of push down on the top of the button. It's hard to describe...if I just push the button straight in like you think you should, it will not open.
Old Jul 14, 2011 | 09:23 PM
Jabberwock's Avatar
Jabberwock
This should be a relatively easy to find junk yard item.
Old Jul 15, 2011 | 03:31 PM
Slvr surfr's Avatar
Slvr surfr
Mine sometimes wont open buy me pushing on it. I've found i was pushing to hard and as soon as i hit the button with the least amount of pressure it opens every time. Go figure!
Finicky cars i tell ya.
Old Sep 29, 2011 | 11:11 PM
Bobzi's Avatar
Bobzi
thnxx guyz i managed to open it!! i had to press the button then use a small piece of metal from below to pull it manually.. it had to open and close as if it is stuck from inside .. nwayzz not a big deall imma keep the coins in my pocket!
Old Sep 30, 2011 | 10:18 AM
jayclapp's Avatar
jayclapp
The front cover is easy to remove. It is held in place by a couple of tabs on the bottom of the cover. Easy to take off. When you get it off, you will see that the button and latch mechanism is attached. Just a lever pinned in place and a spring for latching.
Look to see why the latching lever is not springing into it's place, which is a channel. If it's off to the side it won't latch. The whole lever mechanism is fairly sloppy. If the tab on the left side is broken, the latch will no align with the slot it must go thru.
If it won't open I would think you could probably silde a 3x5 card in at the top and disengage the latch.
Suggest you take the cover off and look it over and see if you can fix it. It might be as simple as pushing in on one side of the button if part of back side is missing.
Old Nov 15, 2011 | 04:56 PM
Lexi65's Avatar
Lexi65
I broke the button to my coin box, how do I replace it or get it from?
Old Nov 16, 2011 | 03:37 PM
Lust4Lexus's Avatar
Lust4Lexus
get it from sewell. Probably will need the whole unit.
Kontil
Feb 9, 2024 04:02 AM
FUZCO
RC - 1st Gen (2015-present)
Jul 23, 2015 06:15 AM
P128sniper
Apr 17, 2014 03:19 PM
pk3
RX - 1st Gen (1999-2003)
Apr 9, 2013 12:46 PM
WhoDat
Aug 21, 2010 06:40 PM
