LS400 Hidden Features
Old Jun 18, 2008 | 05:55 PM
  #76
rsg's Avatar
rsg
CL Folding 3,000,000
When the key is in the ignition and you lock the doors manually, they will automatically unlock.
Speaking of locks, does anyone know how to set the car to automatically lock the doors when put in Drive?
Old Jun 19, 2008 | 07:32 PM
  #77
dfkd's Avatar
dfkd
Originally Posted by UCF11
Another feature about my celsior is that it doesnt have the stereo aerial in the rear 1/4 panel like the ls400's do. I honestly dont know where it is. but I get great reception. (does anyone know????)
If you look at the top section of the rear window defroster you will notice that the brown lines are in a different pattern. That is your antenna.
This was standard on most high end JDM cars (Toyota Crown, Nissan Cima etc.)
Old Mar 14, 2010 | 10:51 PM
  #78
sam12345's Avatar
sam12345
Originally Posted by PureDrifter
wont kill the motor the MOST it could do is throw the gears out of alignment if they are already pretty close to being derailed (or de-geared w/e )
I would not do this. This features is to set the soft stops after repair ect.. What you are doing is letting the motor stall out on the hard stop and putting the entire force of the motor on the gearing. It will definitely wear your gearing prematurely. It would be like holding your steering wheel against he motor until it stalls.
Old Mar 15, 2010 | 02:47 AM
  #79
Rollaboy's Avatar
Rollaboy
Does anyone know if its possible to get the first gen 1991 LS to flash the indicators when locking and unlocking the car with the remote?
I always have to look inside the car for the alarm led to make sure or check the doorhandle. Dont want to let it be parked unlocked because i didnt push the remote properly.
The "problem" is that the door mechanism is so quit so i cant always hear if it locks the doors.
Old Mar 15, 2010 | 05:10 AM
  #80
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500,000
there should be a alarm indicator on the instrument cluster.
Old Mar 15, 2010 | 08:10 AM
  #81
Rollaboy's Avatar
Rollaboy
Yes i know but like i wrote i have to look inside the car to see if its locked. Many times im in a hurry and closes the door and walk away and then find the keys and push the button.
There is not much remote key if i have to stay right beside the window and push the button to make sure its locked if you know what i mean.
If the indicartors were blinking or the siren made a sound i know its locked. Just like a normal alarm.
I just dont want to install a new alarm system just to get those features. And i want to use the button that is on the key instead of having another thing hangning with my keys. Got so many keys already.
Old Mar 31, 2010 | 10:16 PM
  #82
Turboo's Avatar
Turboo
Hi,
my friend has LS400 99 and he noticed that under the steering and under the plastic cover, exactly next to the small dim light, there is a push button!!!
any body know what is it for?
Old Mar 31, 2010 | 11:28 PM
  #83
PureDrifter's Avatar
PureDrifter
BahHumBug
CL Folding 100,000
turns the alarm chirp from when you lock/unlock the car on/off.
Old Apr 1, 2010 | 12:35 AM
  #84
Turboo's Avatar
Turboo
can you elaborate more please.
do you mean it will shutdown the beep that comes when he locks the car with the key remote or unlock it with the key remote?!
Old Apr 1, 2010 | 12:54 AM
  #85
PureDrifter
BahHumBug
CL Folding 100,000
yes, exactly.
it does NOT affect the alarm siren.
Old Apr 1, 2010 | 02:45 AM
  #86
Turboo's Avatar
Turboo
yes, exactly.
Many thanks
Old May 8, 2010 | 09:24 AM
  #87
SRV1's Avatar
SRV1
I noticed when I have my rear view mirror dim switch on, when someone has bright lights not only does the rear view mirror dim but the outside mirrors change to a color of blue. I do not know if that is standard on all LS4's. This is on my 96 LS4.
James
Old May 8, 2010 | 06:01 PM
  #88
PureDrifter
BahHumBug
CL Folding 100,000
not sure about first gen, but all ucf2x (95-00) do that.
Old May 9, 2010 | 04:04 AM
  #89
Rollaboy's Avatar
Rollaboy
Hi,
thats exactly what i want my first gen to do. Anyone know if its possible to turn on the chirps on/off on the first gen?
Old May 9, 2010 | 06:38 AM
  #90
Kansas's Avatar
Kansas
There was no audible "chirp" when the gen 1 90-92 LS400 was locked/unlocked with the remote -- at least on models sold in the U.S. I think the feature was added for the 1993 model year.
