Was coming out of a parking lot and tried to accelerate and my car lost power similar to when you run out of gas and the exhaust started sounding like it was running on less cylinders and and was struggling to accelerate even with the pedal to the floor it wouldn’t go above 30mph so I limped it home about a 10 minute drive I let it sit and and tried to start it again later and got the same result exhaust sounding it was a go kart and would struggle to accelerate to 30 I’ve changed spark plugs air filter and disconnected the 02 sensors to see if that was the problem but I’m still getting the same problem has anyone else ever experienced this or has fixed someone’s car that was acting the same?
I have a video posted of how it sounds
There is a chance it is something like a dead coil, but you have to perform some analysis to get to that conclusion
That would be the very first thing you check because it takes about 1 minute to do. BEFORE pulling the entire passenger side under-dash out to crack open the computer
Just sayin'.
Just sayin'.
My post says to check the coil and the ECU in exactly that order for precisely that reason
My point in mentioning the ECU is to avoid parts swapping, and that it can be multiple factors. Could also be a failed igniter, rotor, distributor, etc etc..
My post that I linked shows how to test the coils and igniters
