sc400 HELP!
Old Apr 4, 2010 | 03:01 AM
jy_SC400's Avatar
jy_SC400
Default sc400 HELP!
The problem i am having is; The car runs very rich, exhaust stinks when i drive, acceleration is low, (meaning, i need to stomp on the gas pedal in order to go pass....35 plus mph?). So far, i have bought new spark plugs, spark plug wires, and a air mass flow sensor, and recently, a refurbished ECU. But i took it for a drive, and the car had little or no improvements in the acceleration. and i think it has a hole in the exhaust, because its sounds loud and broken lol. The car has been sitting for a while, and we gutted out the catalytic converters. Any possible solutions to make to make this car run????? please help!
Old Apr 4, 2010 | 03:43 AM
Ethix's Avatar
Ethix
Gutted cats could be causing the fuel smell. A faulty o2 senson could be causing it to run rich.
As for the lack of acceleration- When you gutted the cat, are you sure you got everything? It's possible your cat is blocked in some way by either not getting all the material inside or possibly by some other break in your exhaust.
Since you changed the MAF, I'm assuming the rest of your intake (air filter, airbox, etc) is in good shape and not blocked.
I'd check out the exhaust first.
Old Apr 4, 2010 | 01:21 PM
MrFairlady's Avatar
MrFairlady
coil.
Seen some weird issues with bad coils.normally the lower one.
Old Apr 4, 2010 | 01:40 PM
FAT HEAD's Avatar
FAT HEAD
Originally Posted by MrFairlady
coil.
same thing happened to me and it was a bad coil. is your rpm needle bouncing erratically when you're driving?
Old Apr 4, 2010 | 03:52 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
I agree also. Bad coil. Check them both.
Old Apr 4, 2010 | 04:05 PM
sc400ghost's Avatar
sc400ghost
Im having the same problem with my 95 400 already replaced one coil fixed for a day. Problem back. So Im starting over again will work on it in the morning. Will keep you posted!!!
Rokas
26
Jun 3, 2018 04:34 AM
Sc400Jimmy
Apr 16, 2014 07:55 PM
Jysc400
Jan 24, 2011 07:05 PM
IggyDrift
Jun 27, 2007 05:35 AM
Lvangundy
Maintenance
Jun 6, 2006 08:51 PM
