Sponsored by: CARiD
Question about retrofits using halogen housings.
Old Feb 14, 2014 | 11:33 PM
SADDLE's Avatar
SADDLE
Default Question about retrofits using halogen housings.
I've been trying to find a nice set of SD headlights and I'm not having much luck finding a set at a fair price. So, I'm now considering doing a retrofit so that I can get everything that I want in my headlights. My question is, can I do a retrofit with my stock halogen/non-HID housing or do I need to use a HID housing?
This is my preliminary build list. Please comment/critique...
'98 GS400 halogen housings
TRS FX-R 3.0 projectors
TRS E-46 R extended shrouds
TRS Morimoto 3Five ballasts d2s
Phillips ultinon 6k bulbs
What else will I need to make this plug and play with my non-hid connections?
Thanks in advance.
Old Feb 14, 2014 | 11:59 PM
tmf2004's Avatar
tmf2004
5% Club. Killing it!!!
did you see this thread?
https://www.clublexus.com/forums/2ge...-hid-caps.html
you weren't able to work out the hID lights from clos430
Old Feb 15, 2014 | 06:35 AM
SADDLE's Avatar
SADDLE
For what it would take to buy those I realized I could do a pretty nice retrofit with my stock halogens, assuming they're OK to use... Haven't ruled them out completely tho.
Old Feb 15, 2014 | 11:41 AM
tiger4life's Avatar
tiger4life
You just need luxurymods brackets to be able to retrofit. You need them whether you have halogen or hid lights. I don't know if they make them for the fxr 3.0, contact them and ask. I bought them for my 1.0's a year ago. You also should search some, there is a diy on here that explains how to do it. It's also on luxurymods website.
Old Feb 15, 2014 | 01:02 PM
Kyle Harty's Avatar
Kyle Harty
Halogens won't be a problem, if you're using luxurymods brackets you just need to file down on of the holes for the clips that you remove from the factory bowls.
If you wanted sportdesign lights I did a Q45 retro where I painted the bezels graphite, it's real close to the SD finish.
Old Feb 15, 2014 | 01:15 PM
tmf2004's Avatar
tmf2004
aren't the reflector bowls different on the HID compared to halogen?
Old Feb 16, 2014 | 06:17 AM
tiger4life's Avatar
tiger4life
The bowl is different but you don't use it in either case. The projector fills that space. 20 seconds to google people.
http://www.luxurymods.com/2gsdiyhidretrofit.aspx
Old Mar 5, 2014 | 06:18 PM
SaiyanGS3's Avatar
SaiyanGS3
Good luck with the sucky morimoto ballast...
LomoFire
Jan 20, 2014 12:42 PM
lixster
Apr 5, 2010 06:59 PM
GSteg
Lighting
May 18, 2008 03:11 AM
flawssin
Mar 28, 2007 03:19 PM
MrHorse
Jul 26, 2001 06:46 AM
