JL amp help???
Old Mar 6, 2006 | 02:07 AM
skpark70's Avatar
skpark70
Default JL amp help???
Im running JL 500/1 to push JL 12w6, initial install I've put 3/8 of its output and last week I've increased to 5/8. The problem is that whenever I crank up the system it plays OK for a while and the bass just shuts off and Im only hearing mid bass thru my other speakers.
Can anyone help me out???
Thanks in advance.
Here is pics of my trunk.
Old Mar 6, 2006 | 02:24 AM
GSoup's Avatar
GSoup
CL Folding 10,000
your amp is 500 RMS and the JL12w6 is only 300 RMS...thats your problem.
Your amp is more powerful than your woofer. Upgrade your sub.
Old Mar 6, 2006 | 07:36 AM
vin 78's Avatar
vin 78
That amp is perfect for the W6, which is rated for 400w rms. JL conservatively rates their subs, their subs easily can handle more power.
If I was going to a sq system with JL products, I would probably go with the same sub/amp combo.
Old Mar 6, 2006 | 07:51 AM
GSoup's Avatar
GSoup
CL Folding 10,000
According to JL audio its 300 not 400. The only part i forgot is that its a 6ohm woofer...So it should be able to handle it as VIN78 stated. How is it wired up?
Old Mar 6, 2006 | 08:06 AM
tonydt1g3r's Avatar
tonydt1g3r
if your amp is just shutting off its either over heating or the sub is maxing out. So when it shuts off try touching it and see if its excessivly hot if not turn the gain down a tad and try it again.
also is the amp 6 omh stable? maybe you hook it up in parralel to 3 ohms
Old Mar 6, 2006 | 08:18 AM
88supramki's Avatar
88supramki
the 12W6v2 is NOT a 6 Ohm woofer...it's a Dual 4 Ohm.
check the way it's wired up, if the JL amp is shutting off try to get it to happen when you can look at the amp. if your ohm light comes on, pull that baby out and send it back. (Hopefully you have a warranty on it) If that keeps happening, it's a good possibility that the amp might be going out. Check your woofer to see if there is any sign of too much current being sent through it.
Old Mar 6, 2006 | 08:27 AM
vin 78's Avatar
vin 78
G soup:
That is the V.2 not the original W6 here's the proof
Its 400 not 300 wrms
BTW the W6 v.2 is dual 4 ohms, not 6 ohms.
skpark70:
that sub can only be wired for either 2 or 8 ohms, and i believe that amp is good for 1.33ohms, so regardless of which way its wired up it shouldn't make your amp go into protection, however, check if its wired correctly (those w6 v.2 wiring is a little tricky).
here's a pic to show you what i mean, the wires could be mixed up...
Old Mar 6, 2006 | 11:16 AM
skpark70's Avatar
skpark70
Originally Posted by vin 78
G soup:
skpark70:
Thanks, I'll check the wirings.
Old Mar 6, 2006 | 11:45 AM
GSoup's Avatar
GSoup
CL Folding 10,000
he never said v2... i assumed he was talking of the original...here...
Old Mar 6, 2006 | 12:03 PM
88supramki's Avatar
88supramki
true, but he did include a picture...which kinda helps determine that it's a v2.
Old Mar 6, 2006 | 12:35 PM
GSoup's Avatar
GSoup
CL Folding 10,000
I was viewing the forum in text mode..
Old Mar 6, 2006 | 12:38 PM
88supramki's Avatar
88supramki
ahhh, that'll do it. no hard feelings
Old Mar 6, 2006 | 12:39 PM
GSoup's Avatar
GSoup
CL Folding 10,000
LOL..i neva took it that way...
Old Mar 6, 2006 | 05:14 PM
vin 78's Avatar
vin 78
Aha, that explains it...
Acer
Feb 15, 2013 12:43 PM
Dunkin1222
14
Jan 26, 2010 05:57 AM
airportis
Mar 30, 2005 01:59 PM
JsN
Oct 26, 2004 03:19 PM
Kevin
Jun 7, 2001 11:41 AM
