alarm installation on sc300
Virtually every wire you will need is located on your factory alarm ecu. Do you have a wiring schematic for it? If not, I can get you a copy from my 93 manual which should be the same.
I presume you are installing yourself? Do you wish you use the existing key to disarm (use the OEM alarm to turn the python on/off) - not recommended. Or are you going to just disable the OEM system - recommended.
Peter
Peter
please send me a schematic, mnkyboy47@yahoo.com. i would like to remove the factory alarm overall. the original key remote never worked since i owned the car. since i have an extra alarm around i would like to use it in the SC. thanks for your help
12volts
white & white/red
ign. harness
Starter black/white + ign. harness
Ignition black/yellow + ign. harness
Power Lock green/yellow - pass. kick panel
Power Unlock green/white - pass. kick panel
Lock Motor
Unlock Motor
Disarm Defeat
Parking Lights+ dk. green wht. plug in dr. kick
Parking Lights- green/blue steering column
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger red/white - wht plug below fusebox
Dome Supervision
Trunk/Hatch Pin red/white/silver dot - dr. running board
Hood Pin
Trunk/Hatch Release black/silver dot + dr. running board
Power Sliding Door
Factory Alarm Arm common with lock
Factory Alarm Disarm green - driver kick panel
Disarm No Unlock
Tachometer black AC check connector
Horn Trigger green/red - steering column
white & white/red
ign. harness
Lock Motor
Unlock Motor
Disarm Defeat
Hazards
Turn Signal(L)
Turn Signal(R)
Dome Supervision
Hood Pin
Power Sliding Door
Disarm No Unlock
cool, is there anything special about installing alarms in the sc. i done 2 hondas, not sure how it compares to the lexus. do i need any special relays, diodes,etc..?? thanks
EM Dot
Oct 13, 2007 07:22 PM
aftermarket, alarm, bypass, diagram, disarm, factory, instalation, install, installing, interfere, pass, sc300, stock, wire, wiring
