Mark Levinson audio
question to those who say this "USB Audio Player Pro" makes a big difference - how is your android phone connected to the car?
bluetooth?
android auto?
analog (aux in)?
usb?
pfm (pure *********** magic)?
something else?
Where external DACs and better music players help is when your source music is good quality, higher bit rate files. Most devices don't have in-built DACs capable of playing higer bit rate files at their encoded rates - they down sample to a lower rate (apparently, some LG phones do have DACs that can however). So, bypassing the device's own DAC and running through an external DAC or app (like UAPP) that can play those higher bit rate files will make them sound better.
For me, when I stopped using VLC and switched to UAPP the difference was immediately noticeable in all my cars. I'm not even using the eq either - I run in "bit perfect" mode. It doesn't matter whether the device is connected wirelessly or wired unless your device has limitations in that area. My files are mostly ripped CDs in a lossless format (m4p - formerly ALAC, but FLAC and other lossless formats are good). This isn't a " true" hi res file of course. Just a copy of the CD in its original sampling rate which is way better than .mp3. For true hi res audio files you need files encoded in DSD or MQA formats (UAPP supports MQA).
bluetooth?
android auto?
analog (aux in)?
usb?
something else?
oh wait, doesn't work with apple iphones.
This is easy to demonstrate go listen to a live orchestra then a recording of the same performance, you can have insane sample rate and still will never capture and reproduce what you heard live.
"People equate specs to good sound doubt that is every going to change. Ultimately it doesn't matter what the specs are how many speakers there are and how many watts it's how it all sounds."
Thanks for the input bud.
And, for all the comments out there about compression, lossless, DACs., etc. almost all the music you're going to find will be CD quality at best. Either because you ripped a CD to a lossless file format like FLAC or because the streaming service gives you "hi res" files which are CD quality (44.1 kHz/16 bit). Some services now offer DVD audio quality now (192 kHz/24-bit) BUT, your phone might not support that level and will downsample during playback. Only way to know is to look up the specs of your phone. Better yet, drop in on someone's forum where they have all the answers already.
(sorry for the wall of words but it's obviously an important subject)
if by bluetooth you're subject to the limitations of bluetooth "re-encoding".
if by analog headphone out (i don't even know if there's an analog line in / aux type input on the car!) you're subject to the limitations of the 50 cent dac in the phone and the analog input is likely re-digitized inside the car's head unit anyway.
if by usb connection OR android auto, then MAYBE the higher bit rate makes it to the car's dac, however, i don't see how the app makes any difference in that case if the digital bits are sent out the usb either way.
Saying the DAC in your phone is important for Bluetooth streaming is like saying the DAC in your CD player matters even when you're using coaxial or optical output. But it is a bit more complicated because the DAC in your phone is actually a purpose built chip that does more than just digital to analog it does basically everything audio. Which means it might have limitations but probably not, the data rate it can output is more than adequate.
Ok, I've said plenty on this and am taking a break. For those with comments still, just download the app and give it a try. Depending on your phone and music files, you may or may not like the result. But it's a free trial so why debate when you can see for yourself?
