Downshift restriction warning buzzer
Old Sep 28, 2018 | 12:53 AM
VanCityLS4's Avatar
VanCityLS4
Default Downshift restriction warning buzzer
I’m posting here for quicker response. The 2010-17 LS460 Sport/Fsport shares the same Direct Shift 8 speed with other F model cars. Having this transmission really separates it from all other LS’s. With full cat back and deleted secondary’s the 1-2 shift and any rev matching downshifts sound awesome..
I often drive aggressively in M mode and experienced the Downshift warning buzzer for the first time when attempting to shift from 3rd to 2nd gear. It beeped twice and would not engage in 2nd. The revs were around 4000rpm when I tried so nothing abnormal. I redline daily for this to happen now after 18 months is concerning. In the last few thousand miles I had 2 drain/fill trans fluid changes (oil was a bit dirty first time), could this be related? I didn’t have trans temp warning light on either. I disengaged from M back to normal and it was fine after.
Old Sep 28, 2018 | 05:40 AM
topguy573's Avatar
topguy573
I'm no pro when it comes to the F and its capabilities/limitations, but in my experience when you are trying to downshift and the car beeps, your RPM's are too high for this to happen. lay off the gas and slow it down, and the car always shifts when it finds it's happy place.
Old Sep 28, 2018 | 08:53 AM
Vervish's Avatar
Vervish
Not exactly sure - but I agree, you were too high in the rev range to drop from 3-2.
I have noticed that the ratio difference between 2-3 is more significant then between the higher gears. Always felt that 3rd should have been a bit shorter to line up with 2nd better.
Old Sep 28, 2018 | 08:58 AM
Vervish's Avatar
Vervish
Stole this from this thread: https://www.clublexus.com/forums/is-...r-the-isf.html
4000 RPM in 3rd is probably about 5,800 RPM in 2nd assuming stock tire sizes on the ISF. Not sure how this translates to LS.
Old Sep 28, 2018 | 10:28 AM
smaggs's Avatar
smaggs
I was looking for something like this! thanks for hunting it down.
Old Sep 28, 2018 | 12:32 PM
VanCityLS4's Avatar
VanCityLS4
Thanks for the replies. I should have mentioned that it wouldn’t drop into 2nd even after I slowed right down. It was stuck in 3rd. I actually recall that RPMs were 3500 not 4000 when I made that first attempt so it have have dropped in. Redline is 6600 on the 1UR and also the same 2.937 Final Drive.
Old Sep 28, 2018 | 01:51 PM
smaggs's Avatar
smaggs
At what point did it eventually shift down to 2nd? And was the car fully warmed up?
Old Sep 28, 2018 | 02:00 PM
VanCityLS4's Avatar
VanCityLS4
I tried about 3-4 times and my speed dropped to about 20mph. I pulled over and shifted out of M and back. Then I paddled thru the gears again in M and all was fine. I was about 30 mins into driving. I understand the tendencies when the car is cold.
Old Sep 29, 2018 | 01:36 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Too bad you messed with the fluid. The level is wrong now and needs to be corrected. Low fluid level is the first thing to check with these gearboxes.
I sent mine for analysis twice, and even at 120k miles with a fair number of track weekends the fluid was still in good shape. I only changed it at 150k because I wanted to put in a new filter and had to drop the pan.
When the level is set correctly, these problems disappear.
https://www.clublexus.com/forums/is-...tructions.html
FWIW, do NOT follow the level setting instructions for your model. The procedure is a little different for your car as it is for the GS F I also have in the garage.
Old Mar 28, 2019 | 11:16 PM
3GSShoe's Avatar
3GSShoe
You used the sequential shift instead of the direct paddle shifters? I thought there was a difference throwing the car into "M" sequential shift vs using the paddles. Paddles will let you redline all day won't it?
Old Mar 29, 2019 | 01:25 PM
AyAyRon's Avatar
AyAyRon
The most exciting part of this thread to me is that you can go 80 MPH in reverse according to that table!
Old Mar 30, 2019 | 02:40 PM
newgsman's Avatar
newgsman
Personally I would much prefer if we could get to 260 going forward in 8th gear.
Zetascry
Dec 20, 2018 03:54 PM
theoryguy3
May 20, 2014 09:00 AM
Menthol
Aug 22, 2013 11:05 AM
smckenna
Jan 21, 2008 04:06 PM
LexusIS-TL
Mar 1, 2007 02:12 AM
