Automatic opening trunk
Old Mar 21, 2022 | 12:24 PM
Soldat79's Avatar
Soldat79
Default Automatic opening trunk
Hey guys,
Some guys and me are looking for a new mod for opening automatic trunk when we press the remote control trunk opening button. Do you know a way to make it ?
Like for the IS gen2:
I think we need to replace with new shock absorbers with more force.
Old Mar 22, 2022 | 05:41 AM
Sasnuke's Avatar
Sasnuke
The 3IS uses torsion springs rather than the 2IS struts.
To make this work on the 3IS you'd first need to make all 4 mounting point for the struts (2 per side) and then find struts that will work.
Ideally you'd find the struts first then determine the mounting points from there.
As noted in the video, the side he put the new strut one had the gap between the trunk and fender get larger.
There is two possibilities for this...the strut is too strong and is pushing too much on the trunk when it is closed...or...the strut is just a little too long and not compressing short enough when the trunk is closed.
Old Mar 22, 2022 | 12:06 PM
Soldat79's Avatar
Soldat79
Ok Sasnuke I get it. I will see that later I'm busy this days. But can we use a new torsion spring with more power or duplicated each torsion spring?!
Old Mar 22, 2022 | 12:12 PM
Soldat79's Avatar
Soldat79
Or this things:
https://www.aliexpress.com/item/1005...martRedirect=y
850R
HS 250h Model (2010-2012)
Nov 25, 2021 04:43 AM
hcopter
Mar 14, 2020 09:03 AM
Ciggy
Aug 4, 2017 05:53 AM
Shawn71
Mar 17, 2010 08:14 AM
shiny250
Mar 12, 2010 08:13 AM
