Trunk release
Old Mar 13, 2020 | 06:09 PM
hcopter's Avatar
hcopter
Default Trunk release
For those of you without the power assisted trunk, when you click the trunk release button on your remote (or the button inside the car) does your trunk lid pop up into the open position or just unlatch and look like it's still closed? Mine just unlatches and sits there like it's still closed and my dealer claims that is normal.
Old Mar 13, 2020 | 06:35 PM
12jimmyjam's Avatar
12jimmyjam
Just unlatches on my 2013.
Old Mar 13, 2020 | 06:41 PM
Tootsall's Avatar
Tootsall
Same as ^^
Old Mar 13, 2020 | 07:22 PM
lesz's Avatar
lesz
The 2 posts above are correct.
Old Mar 13, 2020 | 08:33 PM
Lexmart's Avatar
Lexmart
My 2013 just releases, and barely moves, making it look like it still is closed. I had wondered if that was normal too. I expected a little more popup, but then maybe its so that it doesn't fly open and get things exposed to things like rain? Other cars I had popped open more without opening all the way.
Old Mar 14, 2020 | 05:43 AM
ESully's Avatar
ESully
That is normal, just unlatches on my 2016. I have opened many a trunk at friends repair shop, and all without power assist just unlatch.
Old Mar 14, 2020 | 07:31 AM
mcomer's Avatar
mcomer
The ES300h has the deck lid spoiler and it is also available as an accessory. You can change the trunk lid counterweight
spring to compensate for this weight. Pull back the trunk side trim, remove the plastic rivets first, to expose the spring ends.
Note which slot is used and simply pull the spring end toward you and release it back into another slot. Do both sides and
before reinstalling the trim panels close and trigger the trunk to open. You should get a bit more lift when released. Fine tune
this tension until you are happy!
Old Mar 14, 2020 | 09:03 AM
TechNut's Avatar
TechNut
Veteran: Navy
That is very informative. THANK YOU for the useful tip. I recall our 2015 ES only released but didn't pop up - so consistent with those that responded previously. The question made me curious about our 2019 so I went out to see if its spring adjustment was the same (as I couldn't recall how far it opened), however I just discovered that the remote button doesn't even release the trunk lid on the 2019. I confirmed this is regardless of the position of the button in the glove box. Curious. Time for a post over in the 7th Gen subforum...
EDIT: 7th gen folks straightened me out. Have to press and hold (default setting of .8 seconds) and then it opens fully in about 3 - 4 seconds.
Ciggy
Aug 4, 2017 05:53 AM
jimisbell
Jul 8, 2017 10:28 PM
Shawn71
Mar 17, 2010 08:14 AM
beewhyon
Feb 15, 2009 02:58 PM
davidbenji
Dec 18, 2007 06:40 PM
