steering issue
Old Sep 12, 2019 | 02:28 PM
PATCHEZ's Avatar
PATCHEZ
Default steering issue
for a little while ive had this weird issue with my steering.
if im driving in a straight line for long enough then try to turn the steering wheel gets "stuck" almost like a hesitation but when i put a little more force it starts to turn.
this only happens on the highway and im starting to thing i might have a problem.
what do you guys think?
2016 200t
i had an alginment recently also but its been happening for awhile ive just gotten used to it.
thanks in advance.
Old Sep 12, 2019 | 02:35 PM
JDR76's Avatar
JDR76
A number of GS owners have reported the same:
https://www.clublexus.com/forums/gs-...ing-issue.html
Old Sep 12, 2019 | 02:42 PM
PATCHEZ's Avatar
PATCHEZ
yeah sound like the same issue, I'm gonna say something next time I'm in for service.
what do you think the issue is?
ill ride more into the thread too.
Old Sep 12, 2019 | 02:55 PM
E46CT's Avatar
E46CT
I'd guess it has to do with the way the system is interpreting input and its discernment from driver input and road input (tramlining). There's probably a ton of software engineering and engineering in general that goes into those systems and the car is just getting confused based on a highly particular set of conditions and/or values. That would be my guess.
Should just keep your hands on the steering wheel until you can see if there's any software updates.
Old Sep 12, 2019 | 03:01 PM
PATCHEZ's Avatar
PATCHEZ
that's right i forgot its drive by wire. lol oopps
it almost feels like its a lane keep feature lmao
Old Sep 12, 2019 | 03:05 PM
E46CT's Avatar
E46CT
yeah if you are sitting still while the car is running, try taking one finger and lightly turning the steering wheel. i mean really light. less than 1/8th an inch to 1/2 an inch. and do it slowly. you can sort of feel the car getting confused and sort of lightly assisting the steering. kind of gives you insight as to how the system is working and thinking. it's fun to try. you'll feel a slight tug, then the car sort of stops trying, then tries again.
Old Sep 12, 2019 | 05:11 PM
JDR76's Avatar
JDR76
To be clear, the steering has electric assist, but isn’t a steer by wire system.
Old Sep 12, 2019 | 10:27 PM
sirdizzle's Avatar
sirdizzle
I thought I was crazy and/or car was tramlining, but very rarely, this happens to me too.
Old Sep 12, 2019 | 10:44 PM
RocketG35's Avatar
RocketG35
I have the same issue. There was another thread about this posted a bit ago too. I’m wondering if this is a safety issue TBH.
Old Sep 13, 2019 | 04:54 AM
Sasnuke's Avatar
Sasnuke
I'm wondering if everyone that's experiencing this just recently had an alignment done.
The OP did mention an alignment was done recently.
In reality you're supposed to calibrate the steering after an alignment is done...rarely does anyone do it...one, because it's difficult to do without a Techstream...and two, no one knows it needs to be done.
There's 2 calibrations that needs to be done...Zero point calibration of the Yaw Rate sensor and Zero point calibration of the Acceleration sensor.
The procedure starts with the old calibration information being cleared, and then you set the Zero point for both.
In a very very basic sense you're telling the Steering ECU what the new "straight ahead" parameters are.
It may or may not make a difference here...it may or may not be the cause of the steering issue being described.
Old Sep 13, 2019 | 08:19 AM
arentz07's Avatar
arentz07
When I am slowing to a stop over uneven pavement I get some pulling from the wheel. I always assumed it was just due to the pavement... Since it's only when I am braking. Never had any issues at speed.
DoTheDrew
May 11, 2024 07:04 AM
4889lx570
LX - 3rd Gen (2008-2021)
Jun 15, 2015 11:43 PM
DPK*David
Oct 23, 2013 04:12 AM
sanchez469
Mar 10, 2009 11:38 PM
