I just recieved a mishimoto catch can and I had ordered the large size (7" I believe) and its huge! Does anyone know if it would even fit i am also confused because it only came with one hose.
I think it'll fit, but it'll be a PIA to dump it out. As for the hose, you need at least one for each port, maybe it's long enough were to can cut it into two?
Hm, I suppose I owe you an apology as I honestly thought you were trolling me given your response to my other post in the sway bar thread about using a breaker bar. That doesn't look that bad actually. I rejected the idea of just zip tying it since it's almost $200, and I live the principle of not cheaping out on things when I've already invested into something. I have the same can so is it actually just zip tied using the supplied bracket holes? I figured it would need a full on metal bracket given it's weight.
show me your Cat Catch, i have ton of bracket for 2nd IS , i just brought a whole bunch of brackets home from my Company that fits with 3rd gen IS lol, tomorrow Good Friday Lexus Close i cannot get my PCV ill do it Sat ill post pic in Gen3 forum
the small bracket they include is quote unquote "universal". I've got some pieces of metal screwed together atm as a makeshift bracket (two L shaped one of which is a corner bracket) but it would be awesome if you had a legit bracket.
Iv looked around the engine bay and can't seem to find a spot does anyone have any suggestions
most people mount on the front driver side near the coolant reservoir. That's the only place I can think of that has enough room to fit that huge thing of the top of my head.
it doesnt say that the pvc goes into the "in" or "out" of the catch can.
So is the valve that's connected to the engine block, goes to the breather or the in where a tube goes to the bottom of the can?
And does the original pvc tube connects to the "in" or the "out" of the can?
As XSV stated on page 1 - "The original PCV hose is connected to an extension which goes to the output port of the OCC. Another hose is hooked up from the PCV valve to the intake of the OCC "
The 2 tubes gotta FACE INSIDE to the driver where PCV is, you face it sideway hard to RUN THE HOSE 2nd gen IS has super limit space unless you're willing to use long hose. Check out how i install mine on 3IS https://www.clublexus.com/forums/is-...r-gen3-is.html
