Mishimoto OCC install done. Downsized the 1/2 fittings to 3/8ths brass fittings, got some 3/8ths fuel hosing cut to 3ft, and a bunch of zip ties complete this install. Should have known to cover my face before being sprayed with fuel when disconnecting the 12mm fuel line bolt. No codes so I hope the install went smoothly.
You could possibly rotate your can 90* clockwise and then shorten your hoses for a cleaner install. And or look into finding a 1/2" male to 3/8" female adapter then use a 3/8" NPT male to 90* 3/8" barb so you don't need large swooping radii in your hoses. Just an opinion. But big thing is that you got it on and it's starting to keep oil out of the intake.
Thought about rotating it, but it seemed a little cramped. I thought there were some drawbacks to having 90 degree bends? I do have a 90 degree 3/8ths to 3/8ths that I bought but I didn't use it given that more cuts and gaps could possibly lead to more places for compression loss or something like that is what a guy at the local hardware store told me.
^^just like smitty said, I just went to the local hardware store plumbing section.
Can someone please tell me the airflow direction in those hoses from the image above? I am buying the catch can that have in-let and out-let connectors. -Thanks!
From the original PCV hose connected to the engine, you connect another hose to it and run it to the OCC to the IN port. You then connect a hose to the OUT port on the OCC and connect it to the PCV valve on the engine. As always, refer to page one for visual reference.
I have a chance to look at the 5th image on the first page again and look like installation were opposite to what you said. PCV valve connect to the OCC inlet and the PCV hose connect to the OCC outlet instead.
