Door Sensor Issue
Old Jul 25, 2012 | 12:32 PM
Snafu783's Avatar
Snafu783
Default Door Sensor Issue
Hi,
My rear passenger door sensor (the one that monitors when the door is open or closed) is acting up and constantly signals to my main screen that the door is open, even though it isnt. I removed the small floor panel and can see the long black tube that I assume has the sensor, or wiring to the sensors, to maybe check if it was loose or something but do not know what I am exactly looking for. Looking for any help on the matter since everytime I lock my car the alarm goes off because it detects the door being open.
Old Jul 25, 2012 | 12:33 PM
Shervin350's Avatar
Shervin350
2010 IS, take it to dealer
Old Jul 25, 2012 | 12:35 PM
Snafu783's Avatar
Snafu783
Its a salvage that was repaired to my knowledge...no warranty. Would they charge me to take a look at it and possibly tell me whats wrong?
Old Jul 25, 2012 | 01:11 PM
Snafu783's Avatar
Snafu783
This problem never occured before so I'm wondering if its just a loose connection or something I can easily repair on my own.
Old Jul 25, 2012 | 01:14 PM
Individual's Avatar
Individual
The first thing I was going to ask is if it has been in an accident, but the salvage title speaks for itself. I would definitely suggest checking it yourself. If you take it to the dealer, they will charge you a diagnostic fee. If you want to save yourself the headache of trying to find it, you can have them diagnose it for you, to tell you what the parts and labor will be, and then try to tackle the repair yourself. I would stay the hard part is trying to find the cause.
Old Jul 25, 2012 | 01:19 PM
Herofmine's Avatar
Herofmine
If your car was fixed good, don't tell them that you have salvage, they will never know unless here any visible signs of accident.
Old Jul 25, 2012 | 01:21 PM
Herofmine's Avatar
Herofmine
If your car was fixed good, don't tell them that you have salvage, thry will never know unless there is any visible signs of accident.
Old Jul 25, 2012 | 01:51 PM
Snafu783's Avatar
Snafu783
That is true. However, I did go to the dealer for regular maintenence when I first got the car. I think I might have said the car was salvage then Either way, i'll try to play with it tonight to see if maybe there is a loose connection that I can visibly repair. If not, ill probably have to go to the dealer...
Old Jul 25, 2012 | 07:02 PM
Gville350's Avatar
Gville350
It's a "common" issue, even for a non-wrecked 2IS. Here's my thread on the exact same problem and how I fixed it for free.
https://www.clublexus.com/forums/is-...is-closed.html
Old Jul 29, 2012 | 09:30 AM
Snafu783's Avatar
Snafu783
Wow, I saw this post just in time. I was on the way to the dealership when i read through your thread. As of now super glued a small thick piece of rubber to the actual area of the door where it hits the door sensor "button" on the car. Before, while the window was down, I could pull on the closed door gently and it would beep that it was open. After applying the rubber piece I tried doing the same thing and no issue!
So far it looks good, but will keep you guys updated with its progress. Thanks again.
Old Jul 29, 2012 | 06:41 PM
Gville350's Avatar
Gville350
Great to hear! I first tried a less ghetto fix by shimming the actual door switch, but I didn't have the right sized 6-star driver to do it. Oh well, no one will ever notice it is there anyways.
BinaryJay
May 24, 2020 07:31 PM
RallyVT
Oct 31, 2017 10:16 AM
GQis350
Dec 14, 2013 01:33 PM
NYKnick101
Nov 8, 2013 01:32 PM
roblee8908
Sep 9, 2008 11:19 AM
