Right rear door chime/warning...when door is closed
Old Oct 8, 2011 | 01:58 PM
Gville350's Avatar
Gville350
Default Right rear door chime/warning...when door is closed
Ok, so I've had this problem mainly in the mornings starting this fall...as it is now getting a lot cooler in the mornings. It first started doing it only when getting aggressive in a left-hand turn. But as of this morning, it is now doing it in VERY slow left-hand turn and going straight sometimes. Had my fiance in the car with me this morning, and she was getting more ticked off than I had been. When the warning on the cluster shows up the dome light turns on, a chime dings, AND sometimes the car unlocks all of the doors at speed.
So, I'm just curious if others have experienced this problem and what you've done to fix it. To see if it helps, I've glued a simple, small slab of rubber from an old hood stopper and glued it onto the plastic door molding where the door switch meets the door when closed. Hopefully its a simple fact that the plastic door molding over time has compressed and is now further away from the switch when the door is closed and is not closing the circuit intermittently . The addition for the rubber should hope close that gap.
I'll see in the morning if this fix worked...hope that is all it is.
Comments/stories/suggestions?
Old Oct 8, 2011 | 03:12 PM
calvin2376's Avatar
calvin2376
https://www.clublexus.com/forums/is-...e-turning.html
Old Oct 9, 2011 | 12:07 PM
Gville350's Avatar
Gville350
So far so good. Guess the piece of rubber was just enough to push the door switch trigger in that much farther to close the circuit. The true test will be early tomorrow on the way to work I guess.
Old Oct 10, 2011 | 11:20 AM
Gville350's Avatar
Gville350
This morning I experienced ZERO door chimes/dings/dome light action. The DIY $0 fix worked...may not be pretty, but works!
Emilaman
Dec 13, 2017 11:14 AM
MrMark
Jul 2, 2015 03:37 PM
ATLSam
IS C
Apr 13, 2012 05:27 PM
hammer0008
GX - 1st Gen (2003-2009)
Jan 25, 2011 06:35 AM
Bunkey
Mar 12, 2009 05:51 PM
