Halogen DRL and High Beam Question
If I replace my halogen bulb to a different colour, at low output will it be the exact same colour as the yellowish OEM ones or it will be a different colour but with less yellow ?
If I install HID 6000k on my low beam and fogs, will my high beam still be effective? Reason why I'm asking is because if I use my high beam and I can't really tell the difference if it's on or not due to my HID lighting, I might consider LED DRL
Do you have stock HIDs now or just halogens for the low beams? If you have stock HIDs right now, then the actual light output/brightness should actually drop when you install 6000K - lumen output drops the higher the color temperature, and your stock HIDs are 4100-4300K. So if you currently have stock HIDs, changing to 6000K actually won't make the lights any brighter in terms of lumen output so it won't drown out the high-beams any more than your stock would.
If you don't have stock HIDs for low beams but instead have halogens, that may be a different story because pretty much any HID kit will be brighter than stock halogens.
In any case, I don't think you should be concerned about low beams/fogs "drowning out" or "overpowering" your high beams - they'll still be very useful and visible as high beams no matter what you do with your fogs and lows.
I have 5000K low beams, 3000K fogs and stock halogen DRLs/high-beams and my high beams are still very effective as high beams. I was in the same position as you - didn't like the yellow color of the DRLs but didn't want to go LED and lose my high-beam functionality.
One option is to go to your dealer and have them turn of DRLs entirely and you never have to see them again.
If you want to change your DRLs, your options are pretty much go LED and lose high-beam functionality, or turn off DRLs entirely.
The answer to that question is no, mainly because the fogs are already low to the ground and pointed somewhat down, and the lows are aimed down as well, but the high beams are aimed fairly straight ahead, so the light it emits is sent higher than any other source of light on the front of the car. So no matter what you do to your fogs or lows, your high beams will still be effective because they fill a different area with light (a broader and higher one) than the other two.
