AGGRESSIVE ISX50 wheel thread
This is Banda's car on 18x10 and 18x12.5
Full specs(-offset)
Front Wheels: 18×10 (3″ lip)
Rear Wheels: 18×12.5 (4.5″ lip)
Front Tires: 245/35/18 Hankook Ventus V12
Rear Tires: 295/30/18 Hankook Ventus V12
Front Camber Settings: -2
Rear Camber Settings: -3
Suspension: Tein SS
Appox Drop: 3.50″
Full specs(-offset)
Suspension: Tein SS
Appox Drop: 3.50″
Full specs(-offset)
Suspension: Tein SS
Appox Drop: 3.50″
Full specs(-offset)
Suspension: Tein SS
Appox Drop: 3.50″
Nice specs though
You've going to have a lot of issues... I'm running 19x9 +11 up front and I had to shave like a **** and I still have rubbing issues...I can't go nearly as low as I hoped. My rears are 19x9.5 +13 and I only rub the sidewall on really big dips.
Have you thought about removing your fender liner? Or pulling your fenders?
So many run spacers that it shouldn't be an issue for me. I just never ever have liked spacers. I'm wierd. I know.
I'm the paranoid type. The more "grooves" my lug nuts have to bite onto the better I feel. Spacers decrease the amount of contact area my lugs have to grab onto.
ichiba v1 comes with studs. i swapped the studs on my IS350 to longer ones just in case i was ever using spacers on a particular set of wheels. tap them out with a hammer. using an open ended lug nut (not aluminum) use an impact wrench and pull them back through. super easy
btw the "grooves" are called threads
as for your front you should not have shaved the front. always roll so if you need clearance, you can pull with ou the fender rippling or becoming wavy. and 19x9+11 with a 215/35 or a 225/35 to run low needs some sort of pull.
19x8.5+15 215/35 (with clearance for lower offset) and 19x9.5+15 tucked the edge of the rim with out hitting or rubbing in the rear.
of your ride twenty..!
Those wheel look HOWT!!
toHn
