Cooling System Issues
I have an issue and was looking for some feedback or solutions. I have a 2007 GS350 with 157,000 miles. Back in November my water pump failed. I replaced the pump, radiator cap and serpentine belt but not the thermostat or any of the hoses because they all looked fine (hoses are original and were free of cracks and not stiff). Everything ran fine for three months. About a week or so ago my lower radiator hose slipped off from the lower portion of the radiator. I thought that maybe the thermostat malfunctioned and caused the pressure to built in the system causing the problem. I drove for a few days and rechecked my connections and noticed that the same hose was starting to slip again. I was wondering if anyone else has ever had this issue or have any thoughts on what would cause this to happen. Thanking you all in advance.
I had great luck with worm hose clamps, have them on many cars, but there are special clamps for radiator hoses. You may sometimes have to tighten them after a few cycles, but I never had leaks in decades from them. Even if there is a tiny leak, there is zero chance losing all your coolant.
The factory clamps are springs and can certainly wear out. Like I said, Ford suggests replacing them, 99/100 they are ok, but after 170K miles...the chance for failure goes up. Maybe Lexus has replacements? Those clamps are precisely engineered to the diameter of the hose and fitting, I've seen new hoses that are too big for the original ones. I know they have to be put back in the groove they came out of if you reuse the hose.
Just my 2c
I'm not sure between the air intake hose clamps and the radiator hose clamps, I assume they both run the same type of materials, and I can tell you, after removing and placing the clamps on and off the intake piping, they've definitely grown loose (and I've since replaced them with T-Clamp hose clamps).
Link for reference: https://www.usplastic.com/catalog/it...RoCdIwQAvD_BwE
Maybe you can try these clamps? I've used them on my turbo vehicle before, running 30 psi with absolutely no issues (your radiator cap should release pressures well before 30psi). When I used the cheap hose clamps, they used to POP off under load constantly, eventually cutting the rubber hoses I used so I had to replace the hoses.
FWIW: If you go the same route I used, don't OVERTIGHTEN, my friend and I were doing the thermostat (which I find is really cheap, so you should replace yours either way), he did the easy work by retightening the hoses while I did the thermostat and he overtightened it and cracked the radiator inlet. Also there should be notches past the tip of the radiator, make sure you tighten the hose after that notch.
Here's a photo for reference (notch/ring):
GL! Hope this helped
I would almost just replace the lower hose at this time, just to be safe and rule it out, and make sure you bleed the system of any air pockets again.
Just my 2c
Link for reference: https://www.usplastic.com/catalog/item.aspx?sku=31356&gclid=CjwKCAiAoNTUBRBUEiwAWje2lij146KV1pH_RPaeerz7ZzlPUK-Ierig7CQmAGbVqeFm0nouAP6g6RoCdIwQAvD_BwE
XxGoKoUxX Thanks for the suggestions and advice wish i saw your post sooner I already ordered OEM clamps from Toyota this morning arriving tomorrow.
. Any shop is going to put a worm clamp on it and call it a day.Those clamps XxGoKoUxX posted are very good, because they exert uniform pressure unlike a worm clamp. You could still overtighten them.
