Top hose prob
Old Dec 17, 2011 | 06:25 AM
msc300's Avatar
msc300
Default Top hose prob
My sc300 top radiator hose has to much pressure. Searched already cant find anything heat is coming out cool water pump,thermostat,radiator all new bottom hose doesnt get hot no overheating at all need help
Old Jan 13, 2012 | 01:31 PM
Lexusoarus's Avatar
Lexusoarus
I have the same exact problem...I changed out my Radiator, the hose, thermostat and cap. The car isn't running hot at all but the top hose is pressured like a freaking balloon and it's new. I replaced the hose because the other one busted from so much pressure. So what I do is drive to work with the radiator cap slightly on to release pressure.
Old Jan 13, 2012 | 03:56 PM
Nova's Avatar
Nova
msc300 you might have an air pocket or the radiator might be clogged. can u give me some more info about ur cars maintenance? also where in ? NJ are you i might be able to lend a helping hand
Old Jan 13, 2012 | 03:58 PM
Nova's Avatar
Nova
that is hurting your vehicles performance and correct operation. when you changed the radiator did u bleed out al lthe air properly?
Old Jan 15, 2012 | 10:04 AM
WadeLovell's Avatar
WadeLovell
Have you checked for a head gasket problem? My radiator separated (top of tank from core) when the HG failed. My daughter has been driving the car for the last three years and I suspect the problem developed over time. It is also possible you have a stuck thermostat. They are cheap and easy to get to. In the SC300 the upper radiator hose should not require bleeding. At least that has been my experience and is consistent with the design: the upper radiator hose connects at the top of the radiator and it rises above the level of the engine. TRY this: 1) raise the front end so you can easily turn the wheels in the air (as you would for a power steering fluid flush). 2) remove the radiator cap. 3) Add fluid up to half an inch from the top if space is available. 4) Lightlysqueeze the upper radiator hose and confirm no air bubbles come out. 5) top off the radiator, reinstall the cap, and lower the car.
brad0
Aug 4, 2015 10:32 PM
snsrushing
Feb 27, 2011 11:01 AM
VJZ
Feb 5, 2008 04:34 PM
