Drifting with LSD?
Controlled of course.
I wouldn't think so, but really you are just breaking traction laterally, so the LSD wouldn't come into play until you gave it some throttle, right?
Same goes for donuts, where I wouldn't think it possible, but saw the video of a yellow IS doing one, and they have factory LSDs, so not sure what's up.
Now, when I was at SRT, pre-LSD, Mo sure as hell drifted my car, so the GS can be tossed a little. :eek:
I am hesitant to try for fear of loosing it and totally f'ing up my GS.
Thoughts?
The LSD helps maintain traction -- but it's no guarantee that traction will be maintained. Actually, an LSD or positrac should actually contribute to drift. Go over to the Audi World web site and search under the S4 forum, last time I was there they had links to some videos showing outrageous 4 wheel drifting -- literally the entire way around a real race course.
I grew up in Fairbanks, AK and learned to drift every car I drove. [Well, at least the rear wheel drive ones.] I ended up in a lot of snowbanks along the way. My last vehicle was a Ford Lightning pickup [w/LSD] and that drifted real nice.
Like you, I have not yet gathered the courage to throw my GS4 about, but give me a big enough parking lot and I'd be inclined to toss it about. Actually, the limiting factor for me is the mushy factory suspension -- I'm not comfortable with how it transistions. Next six months or so that will be addressed.
Watching all the videos as of late got me thinking. Is it possible to drift on dry pavement, VSC turned off, with the 3.76 unit?
[snip]
Thoughts?
We'll have to do lunch some time and I'll take you on a few drifts around the block in my car. Actually they're more like controlled power slides than actual drifting.
I agree with what's been said so far, the 3.73 allows me to spin tires at will, but with my 285 size tires there is enough grip to make it more difficult to do donuts. Most cars I see doing donuts are doing it on factory rubber and stock sizes. That may be good for showing off, but not for running quick 0-60's.
What size tire do the IS guys have, doing those donuts? I'll bet they're probably not 285 -19's.
infact, (some would argue to my theory but listen) LSD is essential for drifting, without it you cannot predict when the outside tire will break loose, and its very hard to get the outside tire loose once the inside starts spinning... LSD makes it more controlled and more predictable. Some would say you shouldn't use it but i think with LSD is much better, most drifters agree.
If its not too wet here this weekend (calling for rain), I'll have to try to prove some of your theories!Thanks again.
thats the main reason you'll see drifters lowering their car to the lowest possible... even rubbing is acceptable because they are afraid of rolling the car if hitting unexpected surface..
