The Shakes
Old Apr 28, 2006 | 05:04 PM
iceewillie's Avatar
iceewillie
Default The Shakes
Is there anyone that can help me out??
I have a 98 Lexus GS400 with 90 K miles on it...when I reach 65-74 mph the stering wheel would shake and would stop when I hit pass 80 mph It only occurs between the speed of 65-74 mph. the suspension checked out ok, the wheel ailment done and checked, and tires were mounted and balance...any clue as to what may be causing this?
Thanks
will
Old Apr 28, 2006 | 05:44 PM
Chpsk8's Avatar
Chpsk8
What kind of balance was done on the tires? Roadforce match mount? If not, you may want to.
You could have a broken band in one of the front tires, or they are just out of balance.
A regular balance it probably not going to find the problem.
Old Apr 28, 2006 | 05:49 PM
raceroyce's Avatar
raceroyce
me and several other gs owners have this problem as well. there is a thread somewhere on here that explains what it is. here is the link https://www.clublexus.com/forums/sho...loose+steering
Old Apr 28, 2006 | 05:58 PM
tmf2004's Avatar
tmf2004
5% Club. Killing it!!!
COuld be tie rods, ball joints worn out or caster arms? Any one of those or possibly all of them could be your coulprit.. With that many miles I don't think the suspension checks out.. What does that mean?
Old Apr 28, 2006 | 06:23 PM
e-man's Avatar
e-man
This is a well known phenomenon with the 2GS. My steering wheel shakes a little between 60-65. It's kind of weird that yours does it all the way up to 80, which makes me wonder whether your problem might be different than the well known issue that a lot of us have.
Old Apr 28, 2006 | 07:58 PM
LEXUS_KID's Avatar
LEXUS_KID
WELCOME
Old Apr 29, 2006 | 09:27 AM
Kharizma's Avatar
Kharizma
hmm.. I used to have this problem but since I had my front suspension rebuilt it's not really an issue anymore - i have slight shaking but only for like a split second and the shimmy and such is all gone - maybe check your lower ball joints? and welcome to CL
Old Apr 29, 2006 | 10:07 AM
jonathancl's Avatar
jonathancl
Road-force balance the wheels first.
Use tirerack.com to find the shop nearest you with the most expensive equipment.
Prochamber
Sep 26, 2015 06:44 PM
Darein23
Sep 18, 2008 05:21 PM
Eat_It430
Jun 26, 2007 07:36 AM
400 Degrez
Dec 24, 2006 05:55 PM
SP67GS300
Suspension and Brakes
Aug 29, 2006 12:16 PM
