Remote Key Question
Old Mar 29, 2007 | 12:29 AM
A/X's Avatar
A/X
Default Remote Key Question
I was wondering what needed to be done to program a remote key for a 93 gs300 besides the fcc ID matching, does anyone know?
Thanks in advance.
Old Mar 30, 2007 | 10:07 AM
DBaristo's Avatar
DBaristo
http://www.lexusownersclub.co.uk/for...opic=19509&hl=
Give that a bash
Old Mar 30, 2007 | 10:35 AM
A/X's Avatar
A/X
Originally Posted by DBaristo
Thats for a two button, mine is the single transponder key, but thanks for the input
Old Mar 30, 2007 | 01:54 PM
phollero's Avatar
phollero
Both my keys' alarm button don't work. After ruling out the battery, I asked the Lexus dealer if I can get a new transmitter. They told me the key is only one part and there is some sort of chip installed in the car that is paired with the key. I don't know if it's reprogrammable. All the programming instructions I see on the internet are for later model cars to do that lock/unlock 5 times routine which doesn't work on my '93 GS.
Old Mar 30, 2007 | 02:06 PM
Kaiser's Avatar
Kaiser
Recently mine started to screw up. It locks just fine, but when you try to unlock, the car keeps relocking the car over and over again. Push the button again and it stops. Tried reseting the battery, tried the method above, neither work.
Old Mar 30, 2007 | 10:46 PM
A/X's Avatar
A/X
Well that sucks, I really don't want to pay 300+ for a new key.
Old Mar 31, 2007 | 09:38 PM
NitroDecal's Avatar
NitroDecal
where can a new key battery be purchased, besides the dealer! any online spots?
Old Apr 1, 2007 | 04:56 PM
A/X's Avatar
A/X
You should be able to buy the battery anywhere.
Old Aug 20, 2009 | 09:23 PM
ernest2424's Avatar
ernest2424
Did you ever find a result for this issue? I have a 94 GS and am needing to reprogram mine as well. Thanks.
Old Aug 20, 2009 | 09:43 PM
phollero's Avatar
phollero
No unfortunately without the complete key and receiver module it won't work. It cost too much so I bought an aftermarket alarm to lock and unlock the doors.
Old Aug 21, 2009 | 06:22 AM
ernest2424's Avatar
ernest2424
Thanks in advance.
Were you ever able to reprogram your key to your 93 GS? I have a 94 GS with the original one button key remote and the battery in it died so I replaced it but now it won't work. I'm thinking it needs reprogramming. What did you wind up doing?
Old Aug 21, 2009 | 07:28 AM
moejz's Avatar
moejz
there is also a button to the left side of the sreering on the panel to turn the remote use of / on. check to see if it is in the desired position b4 using the remote,
Old Aug 21, 2009 | 08:23 AM
ernest2424's Avatar
ernest2424
Yep, the button under the steering column is on but still nothing.
rcpeters
Jul 6, 2011 02:58 PM
esssee400
Mar 21, 2011 09:15 PM
nasageek
Apr 22, 2010 11:38 AM
3D Group
Maintenance
Aug 13, 2007 10:27 AM
lexusis250
Jan 3, 2006 02:43 AM
