Build Threads Details on Club Lexus IS-F owner vehicles
JT2MA71's 2014 UW build
Old Apr 6, 2025 | 02:28 PM
  #646
Rossi's Avatar
Rossi
Originally Posted by JT2MA71
Tightens up the factory rubber bushings for less movement.
Any increased NVH?
How difficult is the instal? Looks like the orange one is just ro remove the bolt and swap. The front looks more tricky. Can you run it by me fow to install?
Did you get them from RHDjapan? https://www.rhdjapan.com/super-now-r...rx13-ana1.html
Old Apr 6, 2025 | 02:29 PM
  #647
Rossi's Avatar
Rossi
Are you still running full Icode exhaust? How good are the cats, any smell with headers combo?
Old Apr 6, 2025 | 04:11 PM
  #648
JT2MA71's Avatar
JT2MA71
Yes, still running the full Icode with catted mid pipe. Barely any exhaust smell, the cats work well.
Old Apr 7, 2025 | 10:40 AM
  #649
Rossi's Avatar
Rossi
Any increased NVH?
Old Apr 9, 2025 | 10:24 AM
  #650
JT2MA71's Avatar
JT2MA71
Any increased NVH?
There's always going to be increased NVH when stiffening the bushings. I don't remember if I already had the figs/superpro diff bushings when I did the subframe bushings but the added NVH would be more pronounced with the poly bushings. Install, as shown in my pictures in post #203, you just remove the bolts, drop the bottom metal pieces and add/replace the pieces. Fairly easy, do one corner at a time so the subframe doesn't move/shift. I do believe I got them from RHD Japan but it's been a while so I could've gotten them through my friend in Japan as well.
Old Apr 9, 2025 | 10:30 AM
  #651
Rossi's Avatar
Rossi
^^^^ thank you Ron
Old Apr 22, 2025 | 03:03 AM
  #652
JT2MA71's Avatar
JT2MA71
Installed some Novel/Endless RC F front brake
lines. These are ~1” longer which works perfectly with how I had to clock the caliper fitting away from the coilover *****. Stock length looked a little short when at full turn.
Old May 13, 2025 | 10:32 AM
  #653
JT2MA71's Avatar
JT2MA71
Redid the center console clear coat and decided to try a different finish on the shifter gate trim, I think it turned out to be almost like a brushed titanium look
Old Jun 3, 2025 | 03:28 AM
  #654
JT2MA71's Avatar
JT2MA71
Old Jun 16, 2025 | 02:57 AM
  #655
JT2MA71's Avatar
JT2MA71
Changed up a couple things. Bloxracing Honda shiftknob and black CF (hydrodipped) mirror covers.
White shiftknob was not available with M8 threads so I ordered the M10. Drilled, tapped, and used a thread insert.
Old Jul 15, 2025 | 04:55 AM
  #656
JT2MA71's Avatar
JT2MA71
Old Aug 26, 2025 | 09:07 AM
  #657
JT2MA71's Avatar
JT2MA71
Titanium rear underbrace!
Old Aug 26, 2025 | 02:54 PM
  #658
DK3Fiddy's Avatar
DK3Fiddy
Nice!
I remember seeing a post from the guy that had these Ti braces made. I knew it was just a matter of time until one of these found its way onto your build. 🤣
Old Aug 31, 2025 | 05:19 PM
  #659
JT2MA71's Avatar
JT2MA71
F Sport brace
F Sport brace, 12lb 12 oz.
Titanium brace
Titanium brace, 6 lb.
Old Sep 1, 2025 | 10:48 AM
  #660
Rossi's Avatar
Rossi
Ron, what are you using to fasten the heat shield? I searched your thread, could find the note of it. I saw @funshine made custom brackets in post #52 (Lexus F-Sport Underbody Chassis Brace on IS-Fthread), I wanted to see what did you ended up doing or how you going to address that.
