View Full Version : Performance & Maintenance
  1. 92-01 tails??
  2. 98 AD or BC?
  3. Shifter Bushing questions?
  4. Just purchased a 5-speed SC with welded diff. Was that a mistake for a normal driver?
  5. Driver side mirror
  6. Highest gear ratio?
  7. Warning light keeps appearing... Help?
  8. timing belt scooting itself off
  9. Wet Nitrous Fuel Tap (Photos Included)
  10. engine rebuild
  11. 1jz single turbo feed plug
  12. extra muffler for drone?
  13. My Headache for the last 2 weeks!
  14. I hate my car
  15. Just got back from the dyno
  16. Timing Belt Lasted 200,000 Miles Tensioner Fell Off
  17. Center console removal
  18. Searching for the right sound for my 400
  19. Flash tune/ data logs
  20. Arp head studs. Which one under cut or regular
  21. 2jz 5speed owner
  22. 98-00 SC300s looking for a 2JZ-GTE writeup
  23. Setting TPS to spec. Only reads "4.74 ohms" Help?
  24. SC400 1jz-gte or 2jz-gte swap
  25. 1jzgte Exhaust manifold gasket/ Turbo oil outlet
  26. Questions about 1JZ Hose Routing
  27. Sc400 shutting off issue
  28. Clean Throttle Body with BG 44K or Sea Foam?
  29. Quick Q: Strong gas smell at all times-EGR M hose?
  30. Recomedation for clutch 92 SC300
  31. check engine light issues
  32. Help with 93 sc300
  33. Heat not working in 98sc400
  34. Excessive Blowby?
  35. Important - SC300/400/GS/MKIV diff drain and fill plug bit type
  36. Cluster Repair!! HELP
  37. 2JZGE vs GTE
  38. Factory Fuel Filter
  39. Virtual Tuning?
  40. 1jz Upgrade
  41. Engine noise only when in gear
  42. Anyone ever ran a TT auto trans from...
  43. 98 Sc400 shakes and trac light flashes and check engine light is on now
  44. 1998 Lexus sc400 engine light and trac light flashes
  45. 1992 sc400 HELP PLEASE CATALYTIC CONVERTER
  46. Bushings replaced or entire rack and pinion?
  47. Custom Alarm Sounds Possible?
  48. Speedometer broken, Odometer and all other work fine
  49. Help me identify this squealing noise in engine
  50. TPS (Throttle Position Sensor) Non-VVTI 5-speed
  51. Super low clutch
  52. Auto pulling in second
  53. Precision Gt 4202 or BW s372 turbo..... Any advice?
  54. 2jzgte vvti what standalone ?????
  55. Hks vs jun 264, which one!!!!
  56. twin scroll turbo on single scroll manifold... ?
  57. 93 SC300 145K need help DTC code 25 and code 26
  58. OReilly Global Auto Trans Fluid??
  59. 2000 SC300 GTE Swap
  60. anyone have Pics on Dual Pump setup for in-tank?
  61. 2000 lexus sc300 intake ?????Help
  62. Lets talk power steering
  63. Squeal Upon Engine Start
  64. Any one here running a supra tt cruise cable on a gte swap?
  65. SRT intake for sc400
  66. Help running rough and dying! :(
  67. Transmission shavings?
  68. SES Light help please
  69. Urgent help
  70. SC300 fuel tank
  71. 2jzgte and 1jzgte wiring harness question?
  72. Stalling/dying issue on a 1992 SC300
  73. Chaser? 1j in sc
  74. Which al radiator best bang for the buck if you have 2jzgte swap?
  75. Puzzled on Tach Connection on 1UZ for Idle Check
  76. 95 SC300 won't idle
  77. Sc400 with 2jzgte which motor mount to use?
  78. 12 cm holset hx35 housing
  79. Car won't start!! Disconnected iacv??
  80. 98-2000 vvti SC400 Intake options
  81. valve stem caps used as shims
  82. Recently finished W58 + 1JZ swap into SC. Shifting/tranny issues.
  83. Resonator Delete SC 400
  84. Question about the A340 transmission
  85. intake manifold gasket install ?
  86. more sc power
  87. Would the timing belt be replaced over 100,000 miles?
  88. Lsd options for a street SC?
  89. my sc300 has a random misfire need help
  90. Sc300 has power, battery is good, but will not start
  91. What do I do with the stock IAT sensor??
  92. Automatic Headlight Question
  93. 1uz twin turbo build
  94. VSV Bypassing...Heating blows cold...
  95. Composite 2jz headgasket
  96. Tank fuel filter?
  97. R154 pricing question guys
  98. 7m-gte exhaust manifold vs 2jz-gte
  99. HELP! No Start after tune up
  100. Aristo swap in my 93 sc300 Wont start. fuel and spark are good!
  101. SC400 "pops" at idle and "shakes" from 40-50 mph
  102. can anyone here identity my exhaust
  103. 1JZ, stock SC400 rear end noise!
  104. Custom fab parts
  105. HELP with blower motor
  106. 1JZ overheating a little
  107. Whats your number??
  108. Reverse Camera Connector Layout
  109. Free Toyota Pre-OBD Datalogger Found!!
  110. 1JZ VVT-i running problems...
  111. 92 SC400 1UZ to JDM 2JZGTE Swap Help!
  112. Search for a Mechanic
  113. AEM v2 Sc300 2JZGTE Cranks but no spark; no igniter
  114. Old Transmission Fluid??
  115. Air Bag Light
  116. Please help no heat
  117. Faulty TPS or MAF Sensor???
  118. I have a maintenance issue? Any help?
  119. whats cuasing this?
  120. anyone two bovs?
  121. Smog fail
  122. Help!! Dying 97 sc3
  123. In need of a DIY for valve cover replacement for a 1JZ
  124. Plugged EVAP vent line
  125. How should I proceed?
  126. Can, it be done?
  127. Anybody here running a chasebays gte harness?
  128. 1jz big twin turbo
  129. Please help car wont start
  130. Just bought a Jdm 2jzge. Few qestions.
  131. 95 SC300 issue
  132. IS300 to sc400 coilovers question
  133. jdm 2jz boost
  134. New ignition key needed?
  135. VSV for Evap?
  136. Whistle/ screeching sound from throttle body
  137. CEL and TRAC Light On Codes (13,17,54)
  138. sc300 vs sc400: in terms of engine swap
  139. Need Help,1JZ Engine Half Built,How to Complete her?
  140. 94+ supra auto trans in Sc
  141. Issue: Buzzing Drone Sound at Low RPM
  142. Engine mounts $1200?
  143. ? about modded knuckles and daily driving?
  144. R154 swap clutch help
  145. Middle vents wont blow
  146. Installed turbo intake now compressor surge?
  147. sc400 how do you get to the rack to install dm ps hose?
  148. Tt ecu help
  149. 1997 SC300 auto trans issues??
  150. 94 SC300 Speedometer Harness Burned Up
  151. Winter is coming...FCD or SAFC?
  152. Where to buy Fuel pump and sending unit
  153. Loud Taps At Cold Start Ups - 95 SC300
  154. You really need a inline fuel filter for the feed?
  155. Let me see your electric fan setups....
  156. SC400 92-97 engine swap to 98-00
  157. Starts with starting fluid..wont stay running
  158. Differences between 1jz soarer and sc400 a340E transmission
  159. Im thinking about straight piping my car but need opinions
  160. Ecu/Tuning Question!?
  161. Help me Fix my SC300 - black smoke
  162. Rear diff identification.. "F2OSZ 3-1"
  163. Which mkiv supra fan and shroud do I need for swap?
  164. How do I route these heater hoses (1jzgte) ?
  165. transmission code
  166. Please help!!!! Car starts backfires when starting to boost.
  167. 1jgte guys on singles what did you do for iacv?
  168. choices, choices, choices...which transmission should i go with?
  169. Does the 1st gen 1uzfe have 2 cam sensors?
  170. Power Steering
  171. NEED HELP!!!car keeps DYING!!!
  172. Cant seem to figure out whats wrong with the car
  173. dyno reading automatics
  174. SC400 W58 Swap Parts List (Clarification Needed)
  175. 1JZ SC400 Cannot Get CEL to flash (Followed wiring procedure)
  176. Need Help, Don't know what to do!!!
  177. sc300/400 pictures!! add on!!
  178. 97 sc300 iacv connector wires
  179. Question: 2jzge vvti vs. 2jzgte vvti
  180. Need Help - How to Put sc300 Distributor back in
  181. 1jzgte !!!!!!
  182. Need Help - How to Put sc300 Distributor back in
  183. aem wideband install help
  184. 97+ sc300 auto to manual help
  185. Turbo Question
  186. turbo question!
  187. Transmission swap maybe
  188. TT usdm ecu in na-t wont start.. Need Help!!
  189. So the "Alternator FIRE O-Ring Leak" happen to me a few hrs ago :(
  190. 2jzge vs 2jzgte oil dipstick
  191. Putting a distributor back in
  192. 1uz in a sc300 5 speed?
  193. question about downstream O2 sensor wiring
  194. SC300 problem..Need help!
  195. Best Headers for VVT-i SC400?
  196. Ecu pin out on aristo blitz ecu?
  197. Start up/shut-off issue.
  198. first na-t build
  199. lexus sc300 r154 help
  200. Help ASAP cold weather poblems
  201. Engine Control 1UZFE
  202. Results of Timing Belt Service
  203. Used intake and wire harness...anyone?
  204. having a problem oil smells like gas
  205. Long Time Member/Rare Time Poster - Car Isn't Starting :)
  206. 97 sc300 1jzgte swap info requested
  207. sc300 running rich help
  208. Prognosis is... blown headgasket
  209. SC400 coolant reservoir replacement
  210. sc 300 wont start after swap
  211. BOV Vacuum
  212. Whats A good turbo For sc 300 2000
  213. SC300 Problems.
  214. SC300 Starter Contact Part #
  215. Fuel injector o-ring part number
  216. need help on some info on the swap
  217. Awesome! My 1JZGTE VVTI will be here next week!
  218. Grumbling Sound From Engine On Start Up
  219. Pics of Your fuel system in your sc
  220. AC vents
  221. Need help with ECU and AFM obd1--->2 conversion
  222. Cam Timing
  223. SC400 being converted to 2JZ-GE w/ Auto - Need info plz
  224. na-t vs jdm 2jz
  225. exhaust manifold and o2 sensor question
  226. common oil leaks?
  227. CA : Failed Smog
  228. From NON VVTI to VVTI..??
  229. Left outer brake light not working!
  230. Just installed turbo....a few concerns...
  231. Rough shifting...?
  232. Sloppy W58 shifter. What about new bushings for TRIPOD Shifter setups?
  233. 1998 sc300 2jzgte swap
  234. Shifter Question ?
  235. After 1JZ ECU Repair Please Help
  236. Won't idle, but............
  237. need a little electrical help on 5speed swap
  238. Help 97 sc300 with r154
  239. Rear end question on LS1 swap
  240. Help guys: Need info on 1JZ VVTI
  241. 1jz won't start after swap need help!!!
  242. weird engine noise sc400
  243. Help!! Sc400 is dieing!!!! +++ +++
  244. My compression test numbers, good or bad?
  245. Removing 1JZ Turbo Manifold
  246. 55K miles 97sc300. need FNG help (maint./engine light)
  247. Sc300 with 3.76 gearing possible?
  248. Ebay w58 1uz adapter kit $175 WHAT?!?!
  249. resurface pads?
  250. Moar SC400 probs
Content Relevant URLs by vBSEO 3.5.2
