Cheapest LSD option for a sc300 manual
sorry i didnt post this in the right spot i forgot again ;0
Torsens:
Toyota 200mm Torsens (T-1 and the rarer T-2) are great for NA cars and turbo cars below 500whp or so. Mind you people get a lot of use from them with powerful turbo JZ cars. The rare T-2 is a stronger design still in use today on new Toyotas but good luck finding one.
Torsens are constantly biasing the torque and are generally considered 1.5-way LSDs. The only other 1.5-way available for SC's is made by OS Giken. It's fantastic and possibly the best of all the available LSDs but far from inexpensive and they take their own special differential gear oil.
The same Torsen T-1 200mm LSD with a 3.76 ratio was also available in JDM Aristo's (Japan's GS300) that had a factory 2JZ-GTE engine and in Toyota Soarers both with manual and auto transmissions (standard on manual Soarers, optional on most automatic Soarers). Later model Soarers got the T-2 Torsen LSDs as did later model JDM Supras and probably later model JDM Aristos but it's still very, very, very rare to find a T-2 LSD made for our rear end housings. Try eBay U.S. and Australia for potential listings of those.
Also... 93-98 USDM Supra NA's (as well as 1993-2002 JDM Supra NA's) did have the option of getting the Torsen LSD as well. For model years 1993-1996 this was a very rare special order option and the final drive ratio was 4.272:1. For model years 1997-1998 Toyota made the Torsen LSD standard equipment on Supra NA's and the final drive ratio was 4.083:1.
A note about buying a used Torsen: Since these LSDs act like open differentials until they have engine load on them the rule of thumb is that the seller needs to open up the rear diff case cover to show that the housing really does have a Torsen T-1 or T-2 inside it. For some model years of the MKIV Supra TT Automatic the LSD was actually optional and this is why any sale needs to show the picture of the Torsen inside at minimum or confirm it on local pickup if you will not be dealing with freight shipping.
Everything Else:
All the other LSDs available are 2-way (they lock up on both acceleration and deceleration) and all clutch-pack type. Their particular traits and quirks vary from manufacturer and model.
Generally they are: the discontinued (but serviceable if you find a used one) TRD 2-way LSD for the MKIV Supra, a 2-way LSD by Kaaz, a couple of Cusco 2-way LSDs, a Tomei Trax Advance 2-way LSD, the OS Giken 1.5-Way and 2-Way LSDs... and... I think that's it for the 200mm size diffs that we have.
All of these 2-way LSDs are going to be $1,000 or more brand new. OS Giken LSDs are around $1,600 new. And then you'll need a good driveline shop to install it for you with the diff bearing rebuild kit that Driftmotion sells. Additionally any diff rebuild for our cars especially if it involves a new differential that has never been in there before will require OEM shims in the specific thickness the rebuilder determines need to be ordered from Toyota before finishing the process. So factor in the extra cost of the diff rebuild kit plus whatever shims need to be ordered and finally labor.
I wish there were a cheap option to tell you of but these are what you'll have to choose from to get an LSD in your SC.
There was a Russian-made clone LSD of a Quaife (I think) that was supposed to fit the 200mm SC/Supra/GS housing and someone demonstrated putting it together in a thread but they never followed up with how well it actually worked and what its quality and long term behavior was. I'm only mentioning it for completeness. It is not a proven and recommended option as yet if it ever even will be.
You can, of course, weld it as well. However, I've done this to more than one car and it's guaranteed that you'll blow the diff, wheel bearings, etc at some point. I'd take my KAAZ all day over doing that again.
Good job finding the source of your headlight issue! I don't think many people suspect the headlight stalk switch but as rare as that failure is it can wear out mechanically depending on how much use it has seen since the 90's.
I wasn't aware you had a welded diff in your car. If that's the work of the previous owner who drifted the car a lot then there's no telling how much abuse it has been through. It might be a good idea to decide on the gear ratio you want and just buy a whole used pumpkin for your future LSD rebuild be it a 4.27, 4.08, 3.92, 3.76 or 3.26 (or early LS400 3.615 but that's the ring and pinion set only, not the LS400 diff casing).
I also prefer a 1.5-Way since I have yet to take my car to any competition event and use it on the street only and sometimes on long distance trips. The Torsen T-1 is very old technology but it's good for my mild 340hp (crank) and before that the NA power output. I'd love to get a 200mm T-2 but they're as rare as a unicorn.
The Torsen T-1's (and maybe T-2's?) do need to be used with care and respect on rainy days though especially depending on the type of tires you use but this also comes with the territory own owning any car with a limited slip and no traction control.
The OS Giken 1.5 Way is preferred by MKIV Supra owners who road race and/or go to circuit racetracks but it's supposed to be very streetable too. A year ago I installed an OS Giken twin plate clutch and I have been very impressed with the quality of their products. However with their LSDs just know that you have to use their particular brand gear oil. There is one alternative oil they also list for their LSD but the optimum oil is still the type they sell for all the LSDs they make. I'd like to have more of scsexy's impressions of his OS diff.
Regarding 2-Way diffs... they're all slightly different in character but Rudy has had good things to say about his Kaaz 2-Way and I know that Gerry (Gerrb) can attest to the quality of the TRD 2-Way diffs he has in several of his SC's (most of them making 900-1,000whp or more. In some cases much more) a couple of which he drives around in every day.
The Torsen is the easiest to maintain and the least obtrusive of the bunch but it has ultimate power limitations in the T-1 type and it's not as predictable once you're at 500whp or so. Builds with a lot of power is the other main reason why people go with aftermarket LSDs: clutch style 2-Way types and the 2-Way and 1.5-Way OS Giken are more predictable and durable with big power. Torsens also are not very good drag racing LSDs.
Ultimately which one is best for you also comes down to preference and driving style but an affordable deal on any LSD, even a clutch pack type that needs a refresh before being installed, also stands out.
