Florida Lexus Club The place for Florida Lexus enthusiasts
Tech support post your question here...
Old Oct 13, 2009 | 09:31 PM
  #106
One_jZ_SC3's Avatar
One_jZ_SC3
Default Changing Evaporator....
How do I change my evaporator on my 92 SC??? I know its located under the passenger sude dash and its a B*tch to get to..thats about it
Old Oct 14, 2009 | 06:42 AM
  #107
SHOLEXMAN's Avatar
SHOLEXMAN
CL Folding 25,000
Originally Posted by YeA 2jZ
damn so i would have to completly remove the entire center console like the whole entire thing ?
Yeah the center console has to go cause the glovebox gets stuck on that piece. Also I think there is a wingnut that you get by the cluster so the center console has to come out.
The whole dash has to come off to get access to it. Center console has to come off too. You need to take the cluster out and also drop the steering wheel ,but not remove the wheel. Thats a 2 person job so you can get it done quicker and not damage the dashboard. You need to disconnect the lines in the engine bay also. If you going to do this your going to need to replaced the receiver/dryer. Everytime you open the system up you let water in it and the deicant bags that hold the water in the system are bad. Along with that you might as well replace all the o rings so that you don't have a issue with them popping off when you re pressurize the a/c system. Its like 2 1/2 pounds of refridgerent to recharge it. BTW did you ever get that key lock clyinder taken car of?
Old Oct 14, 2009 | 08:36 AM
  #108
98$c300's Avatar
98$c300
hey any of you guys know what has to be cut on a LS caliper to fit the SC?
Old Oct 14, 2009 | 09:53 AM
  #109
SH_JZZ30's Avatar
SH_JZZ30
The only thing that actually needs to be cut or removed should be the dust shield. And if you are reusing your caliper bracket bolts, you need to put washers on them or get the LS bolts.
Old Oct 14, 2009 | 10:01 AM
  #110
98$c300's Avatar
98$c300
i had heard someone say.that you had to shave a little off the back of caliper.yeah i know about the bolts SC's are longer.
and has anybody tried puting in IS300 in the rear of a SC?
Old Oct 14, 2009 | 10:31 AM
  #111
98$c300's Avatar
98$c300
John where did you get the Lexus stickers for your front calipers?
Old Oct 14, 2009 | 12:15 PM
  #112
TeeLex's Avatar
TeeLex
Richard, you need to ask John ( Mr.//LRD ), since he has done this already.
Old Oct 14, 2009 | 12:35 PM
  #113
One_jZ_SC3's Avatar
One_jZ_SC3
ok thanks alot!! Yea i did, luckily it wasnt the lock cylinder itself...I guess there is a cylanoid/sensor right next to it when you take out the part..that is what the problem was
Old Oct 14, 2009 | 12:39 PM
  #114
DINH300's Avatar
DINH300
i
It's not going to work unless you get the rear assembly.
Old Oct 14, 2009 | 08:02 PM
  #115
Punky's Avatar
Punky
Ok I have another question!
I have some hard water stains on the lip of my wheels. Any suggestions on how to clean em?
Old Oct 14, 2009 | 08:21 PM
  #116
98$c300's Avatar
98$c300
i tried CLR it comes in a gray little bottle.then polish with blue magic.
Old Oct 16, 2009 | 05:01 PM
  #117
YeA 2jZ's Avatar
YeA 2jZ
SO i am having some rear alignment issues so I wanted to know Does anyone have a service manual type of pic of where the asentric (i think that what they are called) bolts and mounts are for rear wheel alignment. I was told that my driver side rear area could have some issues in this area but i can imagine what it looks like even if i looked myself
Old Oct 16, 2009 | 07:08 PM
  #118
SHOLEXMAN's Avatar
SHOLEXMAN
CL Folding 25,000
This is what they should look like. There are different types ,but one of those has to be for the car lol. There should be 4 total on the rear for the toe and camber. Are you going to buy the parts and have them install them or what? Your taking it to a shop to do the alignment right? lol
http://www.sonoransteel.com/ats_016.jpg
Old Oct 19, 2009 | 09:54 AM
  #119
YeA 2jZ's Avatar
YeA 2jZ
Thanks for the pics bro....
But i got a good one now... Whats the difference between the vvti head of a GE engine and non vvti head. I am talkin physicaly ? i seen a lot of guys over on SF that are NA-T and are going with COP (coil over plug spark) to get rid of the distributior. But i see that some of them use the coil packs and ignitors off the vvti head. Woud it be possible to run the vvti head but with non vvti internals basically making it a non vvti head but still using certin parts to retain the COP. Sounds kinda weird when i read it back to my self but i hope someone understands what i am trying to say
Old Oct 19, 2009 | 06:53 PM
  #120
98$c300's Avatar
98$c300
Default I need help with my wideband
i dont understand these instructions for the wiring.they are in english but look like chinese...all i get is where the Red wire goes and the Black wire.
Connecting the LC-1
3. LC-1 Cable connections:
3.1 Out of the LC-1 come 3 cables:
A. Interface and power cables with 6 stripped ends:
a. Red 12V supply
b. Blue Heater Ground
c. Metallic System Ground
d. Yellow Analog out 1
e. Brown Analog out 2
f. Black Calibration wire
B. Serial In connection, 2.5mm stereo (female) marked as IN
C. Serial Out connection, 2.5 mm stereo (female) marked as OUT.
4. Connect the 12V supply wire to a switched 12V source in your car. A switched 12V source
goes on as soon as the ignition on the car is on. Make sure the connection is fused with a
fuse of minimum 5A.
5. Connect the Heater Ground wire to a chassis ground. Make sure it has a good ground
connection.
6. Connect the System Ground to where you will use the analog out signals. If you use the
analog out signals as input for an ECU or datalogger, connect the system ground to the
ground of the ECU or datalogger.
7. Optionally connect the analog out signals to their intended devices.
8. Optionally connect a pushbutton switch between ground and the calibration wire.
9. Optionally connect a indication LED between the calibration wire and ground. The following
diagramm shows how to connect the pushbutton and indication LED.
