Tech support post your question here...
Connecting the LC-1
3. LC-1 Cable connections:
3.1 Out of the LC-1 come 3 cables:
A. Interface and power cables with 6 stripped ends:
a. Red 12V supply
b. Blue Heater Ground
c. Metallic System Ground
d. Yellow Analog out 1
e. Brown Analog out 2
f. Black Calibration wire
B. Serial In connection, 2.5mm stereo (female) marked as IN
C. Serial Out connection, 2.5 mm stereo (female) marked as OUT.
4. Connect the 12V supply wire to a switched 12V source in your car. A switched 12V source
goes on as soon as the ignition on the car is on. Make sure the connection is fused with a
fuse of minimum 5A.
5. Connect the Heater Ground wire to a chassis ground. Make sure it has a good ground
connection.
6. Connect the System Ground to where you will use the analog out signals. If you use the
analog out signals as input for an ECU or datalogger, connect the system ground to the
ground of the ECU or datalogger.
7. Optionally connect the analog out signals to their intended devices.
8. Optionally connect a pushbutton switch between ground and the calibration wire.
9. Optionally connect a indication LED between the calibration wire and ground. The following
diagramm shows how to connect the pushbutton and indication LED.
We need to give ourselves a hand here .Because we help each other when help is needed . And that's what CLFL is about.
I think I'm going to
now .I need a
..lol You guys rock..Thanks everyone for contributing your vast knowledge. It helps
Last edited by SHOLEXMAN; Oct 20, 2009 at 03:47 PM. Reason: John didn't understand my post right cause he had his gay lovers circle going on lol....
How gay is that ??
No more forum surfing when drunk..
on anther note my steering column is acting up it telescopes but it doesn't move up or down i can hear the motor making noise when i try to move it but it doesn't move, anyone got any advice that can help me out ?
https://www.clublexus.com/forums/sc-...ng-repair.html
Jordan spent a good 2.5 hours on the matter .Not only did he fix the stalling problem .But he remapped the fuel table for all levels of rpm.Thanks a lot Jordan.. I should be able to save some gas now because my car was drinking it like water.
I have to say I noticed your concern when I was hitting my max boost setting. And the car was leaning out .But remember two things .the boost was set at 74 % now for the obx that equated to 24 lbs but remember I had a massive leak because i didn't use lock washer. I never expected to be running the OBX as long as I did.
Basically when the Precision was leaning out we were still at 74 % and with no bst leak that equated to 26.5 .thus the car running in the 12's low 13's
But here is the twist at idle I've turned the fuel pressure regulated down from 40psi to 32 psi.
There's plenty of fuel left to go around .But i can appreciate your concern and say it's been noted. Thanks for your help brother . it's truly appreciated ...
thanks punky i feel honored
in hindsight , i wish i would have swapped out my pistons when i had my motor out and gone with a tt headgasket with some 9:0:1 cp pistons and acl bearings ,, its real nice to know you got a fresh bottom end down there so once you put back in you should be good to go for years down the road provided you opt for proper engine management , proper tune and dont grenede the block
rule of thumb , do it once , do it right and boost away
"to boost or not not boost is not the question , the question is do you have enough funds to fund your decision"
Hurry up and get everything together and get any additional hardware installed, so we can hit the rollers on Wednesday when I"m back. G luck at the track bro
