Florida Lexus Club The place for Florida Lexus enthusiasts
Tech support post your question here...
Old Nov 10, 2009 | 05:50 PM
  #151
SHOLEXMAN's Avatar
SHOLEXMAN
CL Folding 25,000
Just remember your taking a gamble with another used compressor even though the price is deterring. Replace your receiver dryer when you open up the system so it can collect any new moisture in the system. It would also be a good idea to replace all the a/c o rings there dirt cheap in price so why not. If he did it I would believe him cause I haven't swapped tops like that, but I understand now what your saying.
Here are the specs once you closed up the system.
Refrigerant Capacity 1.65 lbs.
Refrigerant Type R-134a
Total Refrigerant Oil Amount 4.8 oz.
Refrigerant Oil Type ND Oil 8 [1]
Good luck even though you might not need it the a/c the next 3 months lol.
Old Nov 10, 2009 | 06:57 PM
  #152
YeA 2jZ's Avatar
YeA 2jZ
thanks for the info
Old Nov 11, 2009 | 05:46 AM
  #153
EDTUN3R's Avatar
EDTUN3R
[QUOTE=SHOLEXMAN;4995681]What year is the car? It might be a common ecu related issue that is why I ask. Do you have any check engine lights on? Your ignitors are first in line before the coils so those could be a problem. Just to clarify both coils? If so sounds like ECU. Get back to me on that.
I have a 93 SC400!
Old Nov 11, 2009 | 05:49 AM
  #154
EDTUN3R's Avatar
EDTUN3R
Originally Posted by //LRD
Ed did you check for the obvious cause like a relay and or the connection .??
Yes I did its gettin power all the way but it ends at the coils I got new coils and its not sending the pulse!
Old Nov 11, 2009 | 04:01 PM
  #155
SHOLEXMAN's Avatar
SHOLEXMAN
CL Folding 25,000
Check and see when the check engine light comes on. Turn the key to the on position not running and see if it lights up. If it doesn't the ecu has a bad circuit. 91-94 1uz ecu's have issues with the capacitors melting and stuff. Where are you in Fl cause I have a ecu that you can use to test it out.
Old Nov 15, 2009 | 08:30 AM
  #156
YeA 2jZ's Avatar
YeA 2jZ
Name this part.......
Old Nov 15, 2009 | 08:51 AM
  #157
SH_JZZ30's Avatar
SH_JZZ30
Heater vsv(vacuum switch valve). I had to replace mine in my 97 because it was leaking. I've also seen people call it the heater control valve.
Old Nov 15, 2009 | 09:00 AM
  #158
YeA 2jZ's Avatar
YeA 2jZ
I have the same problem thanks
Old Nov 15, 2009 | 11:35 AM
  #159
97SCBOY's Avatar
97SCBOY
Ques? iv'e benn hearin a click crack sound on the front of my car for a lil while, turn out while changin my oil, i decided to move my tire up and down side to side and i have play on my control arm so i kno that's bushing for sure... Should i get the polyurethane bushing from dazien?
Old Nov 20, 2009 | 08:12 PM
  #160
EDTUN3R's Avatar
EDTUN3R
Im In Hollywood FL
Old Nov 27, 2009 | 02:04 PM
  #161
EDTUN3R's Avatar
EDTUN3R
I just realized that you are Pretty Far! LOL
Old Nov 27, 2009 | 05:16 PM
  #162
One_jZ_SC3's Avatar
One_jZ_SC3
For the last 2 days my car will not rev past 1500 RPM when the car is turned on idle...when it reaches that point it drops back down and if I hold the gas it just sounds like it hesitates or stops for a second and the rpm falls down(sometimes the car will turn off when the needle goes down). After a few minutes the car will rev out again and if I start driving all of a sudden the RPM falls and I cannot accelorate, the car will jus hesitate...all while the car is still on! WTF!! I never had this issue and it just started out of no where!
I have a 1jz swap auto, not sure if that matters...anyone herd or experienced this before?? I dont know what to call it...
Old Nov 28, 2009 | 06:05 AM
  #163
SHOLEXMAN's Avatar
SHOLEXMAN
CL Folding 25,000
Yeah I saw where you were also yeah so if you want to drive have fun with that lol. Did you ever see what the issue was with the car?
Old Nov 29, 2009 | 10:36 PM
  #164
One_jZ_SC3's Avatar
One_jZ_SC3
Since I last posted this, my car was driving fine again and just a few minutes ago it started acting up ...This time i took a vid b/c I cant explains whats going on anymore: Take a look at the link and if anyone knows or seen this issue please let me know, thanks!
http://www.youtube.com/watch?v=hZ9nsPRhscI
Old Nov 30, 2009 | 04:14 AM
  #165
Wicked SC's Avatar
Wicked SC
First off Jermaine, you might want to put some gas in your tank!
Second, your temp needle reading looks a little too high...
Third, just get yourself a 2J and it will solve all your issues!
We all know I'm no tech or mechanice but it seems like it's something electrical??
Good luck!!
