Different air bag pressure?
Old Nov 22, 2010 | 05:12 PM
PHML's Avatar
PHML
Master Thread Closer!!
Default Different air bag pressure?
Why is it that one air bag needs 131 psi (left front)....and the other only needs 105 psi (right front) to get to the same height?
Does it mean my left front air bag is stretched and needs replacement soon?
Or is it my pressure sensors needing replacement?
Old Nov 23, 2010 | 08:38 AM
vwynn's Avatar
vwynn
could be a few things but.. was this a problem when you first got it?
what setup are you running?
Old Nov 23, 2010 | 08:41 AM
vwynn's Avatar
vwynn
also dont forget the driver side is usually heavier due to you sitting on there, steering column n what not..
Old Nov 23, 2010 | 04:33 PM
rgarjr's Avatar
rgarjr
are the air lines the same length? Could also be the air sensor or gauge not being as accurate.
Old Nov 23, 2010 | 06:42 PM
speedaddic's Avatar
speedaddic
I'd say weight as well. Mine is the same way
Old Nov 24, 2010 | 03:37 AM
lkapimp216's Avatar
lkapimp216
It's is most likely weight load no car is evenly balanced on all four wheels, this was my issue w/ lowering springs all the springs are the same but lowered my car to a different height all the way around I hated if even though the factory springs did the same thing. I just didn t notice until my fitment and wheel gap became tighter. That's why I went with coilovers you can fine tweak everything!
Old Nov 24, 2010 | 04:18 AM
IXI187IXI's Avatar
IXI187IXI
yup its from the weight of the car and you also being on the same side.
i highly doubt its the air lines. if the air lines are different lenghts that would not have anything to do with why 1 bag requires more air than the other. only thing 2 different length lines mean, is that one bag will fill up quicker because it has less line to travel through.
Old Nov 24, 2010 | 12:45 PM
vwynn's Avatar
vwynn
if you feel that the air sensors are throwing something off u can always swap them around to see if the readings are the same way.. this is prolly the easiest way/cheapest way to start the diagnosis.
Old Dec 2, 2010 | 12:42 PM
EN_VY's Avatar
EN_VY
That's the same way with me, but I'm sure it's because of a blown shock for me.
Old Dec 4, 2010 | 12:47 PM
jgc's Avatar
jgc
mine reads differently on both sides but with me in it the pressure stays within 5 psi or so.
Old Dec 4, 2010 | 01:56 PM
phillygs3's Avatar
phillygs3
airlines are longer on one side, I have the same issue especially my rear
Old Dec 8, 2010 | 01:00 AM
skperformance's Avatar
skperformance
get the car corner balanced .
26 lbs is a huge difference , to the point that corner should be hopping all over the place going over bumps .
Also get a quick calibration by airing up all 4 corners to max height equally . Then read if all 4 corners are the same as some sensors might have dirt on them and be blocking the correct readings.
BrettinSA
GX - 1st Gen (2003-2009)
Oct 6, 2017 07:38 PM
carid
Club Lexus Vendor Marketplace
Jan 27, 2016 08:02 AM
ExiledWolf84
Aug 10, 2015 03:04 PM
Greg5OH
VIP Style
40
Dec 16, 2013 08:10 AM
rybikowsky
Jul 7, 2003 08:31 AM
