View Poll Results: Would you be interested in having LS400 brakes on your 2nd Gen GS?
Yes, because it would be cheaper!!
55.56%
Yes, because I like the way LS400 brakes look.
22.22%
No, I still like Supra TT brakes better.
22.22%
Voters: 9. You may not vote on this poll
but RCA works as a camber kit, because it pushes the lower control arm down and not raising the hub and knockle. it will fix your camber but installing the RCA + jacking the coil over back up.
Quote:
i read in another thread that you order your rca from japan. can u give us the info? how much? and the dimension of it?Originally Posted by johnee78
The roll center adapter will straighten out camber because I have it on my car and the before and after camber adjustment is all the proof I need ..Because by installing this you actaully raise the steering knuckle instead of bringing the car down to lower it..this adapter is better suited for those who have coilovers because the front will be lower than the rear...
OK, can you guys clarify a few things for me? I just purchased a LS400 BBK upgrade for my 99 GS300 and im totally lost on what this "RCA" thingy is and where can i buy this custom spacer? Do i have to custom make this bracket/spacer? Someone please give me the heads up on this.
Quote:
im thinking i shouldn't be doing this bbk upgrade on my 99 GS300 until i get coilovers b/c i got bilstein sports/espelir springs combo right now...and if i go through with this install with RCA...wouldn't my stance be out of whack?Originally Posted by johnee78
what about the rears? i just finished putting the supra tt brakes in the front but the rears don't mount up correctly. does anyone make a mounting bracket?
Thanks,
Sid
Thanks,
Sid
Quote:
LS400 calipers design is new than the SupraTT
LS400 calipers are lighter than SupraTT
LS400 calipers will probably give more gentle stopping, since the LS is more comparable to the GS than the SupraTT
Yea... and that's the reason why the Supra brakes were tested the best stock brakes since 1993 until the new Porsche beat it Originally Posted by HKGS300
I would say ... i would prefer the LS400 over the Supra TT because:LS400 calipers design is new than the SupraTT
I just bumped this thread because I'm just starting to semi-mod the GS now. Hmm I didn't hear of the NA Supra guys using any RCA spacer. I guess I'll look into th at on the GS.
NA supra calipers are similar to most calipers on lexus, the "floating" design
supra TT calipers are half aluminum and half cast iron, while the LS calipers are all aluminum (i just mildly polished a spare set of LS calipers, sick!)
supra rotors are larger than LS rotors, plus curb weight on the supra TT is about 300-350# lighter than the LS400 (depending on model year 90-2000)
Quote:
The holes of the caliper will line up (GS, Supra), but the front suspensions are different. The LS400 caliper will clear on the Supra, but will hit the suspension on the GS, that is why you need the rca.Originally Posted by mikevanle
the back half of the LS calipers are bigger than the TT calipers since the LS caliper is all aluminum and the TT calipers are aluminum front half, cast iron back half.
the caliper rear hits the tie rod bolt, some people just cut it down and others use a spacer (RCA) between the lower ball joint and steering knuckle.
i'll be cutting out a spacer on a waterjet for my friend's GS430 to fit a set of LS calipers i got and polished for him, our main concern is that his summer wheels will clear the calipers but his winter wheels will not.
Quote:
alex please reply to my pm's pleaseOriginally Posted by HKGS300
Quote:
Did you ever figure things out with the LS400 BBK?Originally Posted by GS3.0
I'm ready to upgrade the front brakes on my GS400 with the 17" L-tuned wheels and am trying to decide what is the best route. I already have the SS lines & the Axxis pads, but the rotors need help.
A) - new stock rotors
B) - new aftermarket rotors
C) - LS400 rotors & calipers
D) - Supra TT rotors & calipers
with 99% certainty I can say that your wheels will not have the spoke clearance for either the LS or supraTT front calipers.
Quote:
bringing this subject back to life ltuned salinas will fit bbk.
anyone have any information on this rca i remember seeing a picture of a diagram that look sort of like a bow tie. i have access to a 4 dimension cnc router so i know i can make it
