Wheel lug torque specs are for clean, dry threads.
If you lube them it invalidates the factory torque recommendations.
Yeah, I know, people have been lathering on all sorts of lubricants for years, but that's not the way it is supposed to be done.
And if you're using a click-type or digital torque wrench, there's no reason to "round it up" - just use the 76. If they wanted 80 they would have said 80.
Correct, do not put any lubricant on your wheel lugs! If anything, use a wire brush to clean the threads before mounting your wheels.
Agree fully. While I have a manual wire brush in hand, I also hit the hat of the rotor. Learned this from my dentist, who taught me to brush my gums after a thorough teeth brushing!
Do NOT grease the threads. You will over-tighten before you reach the normal torque value. You can break the lug bolts. And, you may wind up with uneven torquing on the lugs of the same wheel, which can cause uneven stress on the rotors.
I used to do it until I found out how bad an idea it was.
