ALH Problem
I replaced the entire headlight assembly with factory parts. Now the driver' side light moves way to fast and far on turns and the passenger side does not move at all. Any ideas. Checked codes and the only code that seems relevant is a steering column wire harness code, but they were working fine before the replacement. Thanks.
What was problem with the original headlight?
also, which light did you change, left or right?
did you disconnect the battery to reset the system or did you try to reset the system with the code reader.
Replaced both of them. The old ones were working before I replaced them. Yes we reset the codes. I will get the exact code and post later. I saw on another thread that when you start the car there is calibration where the lights should move slightly to self calibrate? I do not remember mine ever doing this.
Codes:
B1262 ECU Communications stop
B1421 and B1424 Solar sensor circuit driver and passenger sides
B1441 Air mix dampener control passenger side
B2620 ECU Power source circuit
since you said the old ones worked fine, I would first question the headlight assemblies you just installed.
were they used or new OEM?
as for the codes…ignore B1421 and B1424, that just means the dash sensor doesn’t see the sun.
DshngDaryl had the B1262 code…not sure how he resolved it or it never came back
B1441 sounds like an HVAC servo actuator…I repaired one in my 2002.
https://www.clublexus.com/forums/sc4...1272-code.html
can you confirm all connectors were reconnected?
if so, the new OEM assemblies would be suspect…if you have the old ones, can you reinstall them, that is, if you did the work?
Do you have TechStream?
BTW, are you near Cocoa Beach, asking because I have TechStream we could use it to run some diagnostics
Snap On Tools reader. My buddy is an autobody guy at a Porsche dealer. He is going to use their shop scanner. He believes the problem lies with a control module not the headlight assemblies. I am pretty sure all of the connectors were plugged back in. Seeing my old headlights never did that auto calibrate giggle on start up I suspect the problem existed before the switch out. Thanks to everyone who took the time to reply. I will post when I know something new and the codes that come from the shop scanner.
Margate330
May 20, 2022 04:22 PM
Gtfourever
Apr 30, 2016 08:14 AM
