SC430 window issues
Old Apr 10, 2018 | 09:06 PM
dredkam's Avatar
dredkam
Angry SC430 window issues
Bizarre problem. My passenger window quit working yesterday, from both switches. However, it opens and closes when I open or close the hardtop. I am also getting two indicator lights on dashboard light up, and this all happened together. Suggestions?
Old Apr 10, 2018 | 09:51 PM
GmanSC's Avatar
GmanSC
Silly question, but did you check the passenger lock button (on the driver side) ? Make sure it's in unlock position.
I suspect it has something to do with that button.
Old Apr 11, 2018 | 05:53 AM
Jabberwock's Avatar
Jabberwock
Definitely a good idea to first check the window lock button. If that is not the issue you may have an problem with the door and window ECU located (I think) in the drivers door. First thing I'd do is disconnect battery for a few minutes and then reconnect so all ECUs essentially restart.
Walt4life
Mar 19, 2016 12:41 PM
Zmon
Feb 11, 2016 04:28 PM
foe84
Dec 27, 2012 05:24 PM
dbaze25
May 27, 2011 01:53 AM
tlutsky
Dec 11, 2008 03:11 PM
