OverHeating problem
Old Aug 28, 2016 | 06:01 PM
JohnnyT02's Avatar
JohnnyT02
Default OverHeating problem
My 02 sc430 started overheating one day when I was going to the the store VSC ON/OFF light came on and a bit of smoke was coming out luckily I got it home and discover my radiator had a crack in it. I spent today taking it out and putting in another one in and got it running again but still getting to hot and I'm not sure what else could it be. Can anyone give me advice or know what else could be the problem.
Old Aug 28, 2016 | 06:08 PM
JohnnyCake's Avatar
JohnnyCake
Welcome to the forum!
I'm gonna assume that you installed the radiator correctly, have the correct antifreeze mix, and do not have any leaks.
With that assumption, I'd be looking at thermostat or possibly fan (assuming that you run hotter when stopped).
Old Aug 28, 2016 | 06:15 PM
JohnnyT02's Avatar
JohnnyT02
Thank you
I believe I got it installed correctly the fans are running, no leaks and the anti freeze was a 50/50 mix (hopefully that's the correct mix)
Old Aug 28, 2016 | 06:30 PM
2004sc's Avatar
2004sc
Might take an instant read thermometer and take a reading at the location point of the thermostat. If that is "normal", chances are the thermostat is ok. If the temp reads normal it could just be that your sending unit needs to be replaced. I've had them go bad before and the car temp gauge reads "hot" when it really is not.
Coleroad's Avatar
Coleroad
Making sure that there is no air left in the system. Including the heater core
Bon's Avatar
Bon
Back to what JohnnyCake said about your thermostat. It may be stuck shut. Starting with a cold engine, remove the radiator cap and watch the coolant as the engine warms up. You should see coolant flow when the thermostat opens. If you never see coolant flow then it's stuck shut and must be replaced. If that isn't the problem then you might have a delaminated upper or lower hose that's swelling internally when it gets hot and subsequently closes off the coolant flow. I've had that happen to me many years ago - to a new hose!
Old Aug 28, 2016 | 06:33 PM
2004sc's Avatar
2004sc
JohnnyCake...don't mean to highjack this thread but I noticed that you say you have disabled the NAV "I agree" notice. How is this done?
Old Aug 28, 2016 | 07:11 PM
JohnnyT02's Avatar
JohnnyT02
Went back outside to see if the coolent was flowing and I looked bone dry
Old Aug 28, 2016 | 07:23 PM
Bon's Avatar
Bon
It's likely that it was never full. System probably needed burping and only looked full. Keep adding fluid and watching the flow of coolant as the engine warms up. You might just be good to go!
Old Aug 29, 2016 | 11:53 AM
LexMan2003's Avatar
LexMan2003
How's the circulation? Is your water pump operating correctly? Also, did you use distilled water in the mix?
Old Aug 29, 2016 | 07:24 PM
JohnnyT02's Avatar
JohnnyT02
So listened to both of you and my car seem to be running well now. The temp hasn't moved Attachment 394402. Ty all for your help I truly appreciate it
alladien
Dec 16, 2013 08:16 PM
Blakeg1991
Jun 27, 2013 05:12 AM
jshooter55
GS - 1st Gen (1993-1997)
Sep 23, 2012 05:47 PM
Triple C
Sep 18, 2008 07:56 AM
Dixond
Maintenance
Nov 13, 2003 07:03 PM
