Radiator Problem
Old Nov 11, 2003 | 08:14 AM
Dixond's Avatar
Dixond
Default Radiator Problem
This could go under the Maintance Forum but I need some responses from people with SC's about costs.
I've been leaking coolant for the past few days now and have notice spray marks coming from the radiator. When it gets hot, theres a TINY hole on the top plastic part of the radiator that is just down far enough to be hidden by the fan housing. So when the bubbling starts to happen, the fan shoots the fluid everywhere. I took it into the local Toyota dealership and they told me that because of that tiny little hole in the top plastic part, that I'm gonna need a new radiator. I wanna know if this is true. It's not actually in anything metalic that has a hole. It's just the top plastic part where some of the tubes feed into the radiator. Could this be replaced? I was looking online and found that SC radiators can go for as low as $150 bucks whereas the dealership was gonna charge me $480. The only problem w/ the $150 radaitor was that it says it comes "without a filler neck." What exactly is a filler neck? Could it be transplanted from my old radiator to this new one?
Thanks,
Dix
Old Nov 11, 2003 | 08:20 AM
ToyLexmods's Avatar
ToyLexmods
Well,
Your fairly new and will prob get this from several members. Use the search feature and you will find all your answers.
My opinion, buy the toyota top tank and have it installed at any rad shop. Top tank ~130 bucks....common problem and if you dont care to keep the toyota rad then go the aftermarket for 150.
Old Nov 13, 2003 | 07:03 PM
DredLexx's Avatar
DredLexx
Post
I have the same problem with a 1993 es300 they quoted me $3 bills b4 labor, my leak seems to be in the top of the radiator under the head(rightside), it's leaks all over the front right of the radiator, Im curious what was your final solution if any progress.
JonGS3
Feb 13, 2018 11:26 AM
Solowing
Jul 28, 2016 07:39 AM
pmpdaddyt
Nov 1, 2008 04:26 PM
stallion50
Jun 8, 2006 12:56 PM
